Go to Post The name of the game will be "Conjunction Junction". The robots will be tasked with hooking up words and phrases and clauses. You're welcome. - Travis Hoffman [more]
Unread 31-01-2010, 20:00
Darthturtle808 Darthturtle808 is offline
FRC #2090
Darthturtle808 is an unknown quantity at this point
Version of Labview?
I've been confused by the mandatory 2.0 update for labview. Before the update I had the option of an experimental framework and an advanced framework. After the update it took away those two options. But on the tutorials that I have been looking at http://frcmastery.com , they are still using the experimental framework. Am I supposed to have the experimental framework?
Unread 31-01-2010, 20:23
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Version of Labview?
No experimental framework anymore.
Most of the LV Master videos were done last season and used the 2009 frameworks. The 2009 videos reference the Robot Basic Framework or the Robot Advanced Framework.
They are still good general guides, but some of the frameworks have changed in FRC use and some details have changed or are altogether new.
Unread 31-01-2010, 21:43
FRC #2090
Ok, thank you. Now when we try and deploy code to the CRio, it deploys but the driver station says that there is no code. We did the update to the driver station after we got it. We were only able to deploy and run code using the experimental framework in the older version of labview. Does anybody know of a website that has tutorials for the newer version of labview?
Unread 31-01-2010, 21:53
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
After installing the LabVIEW update, did you reimage the cRIO with the v19 image?
C and LabView version control with Git Nibbles NI LabVIEW 31 17-01-2010 19:22
Ni Labview Version Gandramu NI LabVIEW 1 30-09-2009 16:40
Problems running Default LabView Code Version 3.0 seg9585 Programming 6 01-02-2009 17:23
NXT Kits: Education Version vs. Commercial Version Richard McClellan Robotics Education and Curriculum 5 20-08-2008 16:29
easyC Version 2 fowlerm Programming 3 10-01-2006 22:21
