"watchdog not fed" error
Ok, so we're having an issue with the code here.
For some reason we are getting a "watchdog not fed error" whenever the code is run, however I don't understand what is causing this. We don't have any infinite loops, waits, or anything else that is particularly different from the default code. The only modifications we've made so far is switching to tank drive and two solonoids w/ a compresor Is there something obvious that needs to be added to the default code to make this work? |
| Watchdog not fed | ahudson | Programming | 1 | 22-01-2010 11:26 |
| MPLAB 8.0 error "Can not fit section" | billbo911 | Programming | 7 | 20-02-2008 15:26 |
| "Demo Stamp not found" error message | Gatto | Programming | 1 | 07-02-2007 23:17 |
| Screenshot of "code not understood" or similar error needed! | Elgin Clock | Programming | 3 | 17-02-2006 22:06 |
| Program error - "can not fit the section" | miketwalker | Programming | 9 | 20-02-2005 01:21 |
