Go to Post If regolith ever makes a return, I will jump out of a window. - Oblarg [more]
Unread 31-01-2010, 22:44
dungeonmonkey dungeonmonkey is offline
FRC #2458
dungeonmonkey is an unknown quantity at this point
Question C-Rio download issues
when i want to download the code to the robot, it seems to succesfully complete the task, but when i restart the control system and hook it back up to the classmate, it says that there is no robot code. i have already formatted the C-Rio correctly and have tried putting the default code on (although it may or may not be last years default code). Are there some coding changes that i am unaware of? originally i thought it was just the classmates configuration settings, but if that was the case, shouldnt the jaguar lights still become solid? pls help!!!!
Team modo: "I'm sure it's around here somewhere..."
"If at first you do not succeed, you fail." -Glados
Unread 01-02-2010, 15:05
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
Re: C-Rio download issues
I am assuming you are using FIRST>Download with the correct build file, correct?
have you updated windriver? http://first.wpi.edu/FRC/frccupdates.html
do you have the v19 image? http://joule.ni.com/nidu/cds/view/p/lang/en/id/1534
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Unread 01-02-2010, 16:02
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
If you don't tell the cRIO you want the program to run at startup, it won't be running after you restart the control system. How are you downloading the code? What tells you it seems to succeed?
Why do you have to "hook it back up to the classmate"? You shouldn't need to unhook it in the first place.
Unread 01-02-2010, 19:30
FRC #2458
ok let me make this a little clearer (is that a word ...) basically, we are using a seperate laptop from the classmate to program and compile on (since the classmate is such a crappy laptop) and that is why i had to "hook it back up" to the classmate. I do not know how to tell the C-Rio to run that code in particular on startup. yes, i have the windriver update. yes, i have v19 image on the C-Rio. yes, i did specify the correct path for the built binary image.
hope this helps explain.... pls help
Unread 01-02-2010, 20:21
Software Architect
I still don't understand why you unhook the Classmate at all. The router has four Ethernet ports, so you can have both the Classmate and your development laptop connected at the same time.
Page 21 of C:\windriver\docs\extensions\FRC\C Programming Guide for FRC.pdf might help.
How do you download a program and have it saved to the c-rio 2560DawgDM NI LabVIEW 12 03-02-2010 20:58
Extra C Rio? falconmaster General Forum 26 21-10-2009 17:14
Lights On Compact Rio? excel2474 Electrical 13 24-01-2009 11:35
New Rio Issues, refuses team number and programming Pwolter Technical Discussion 14 26-12-2008 09:19
RIO update? Betty_Krocker General Forum 3 03-12-2008 07:46
