Go to Post Searching is your friend - try it. - Katie Reynolds [more]
Unread 31-01-2010, 22:48
TD912 TD912 is offline
AKA: Chris Leung
FRC #1989 (Viking Robotics)
TD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud of
Ethernet cables not 'clipping' into Classmate PC
We should have reported this earlier, but it appears the Ethernet port on our Classmate PC has been partially broken since we opened it. No CAT5 Ethernet cable (we tried a bunch of different ones) will 'click' and stay in the port. Although just an annoyance now, it's gonna be a bigger problem at the regional...
We already took a close look at the port. Did something break off the Ethernet port that we aren't aware of?
Is there an easy fix for this? I'll try getting some photos of the port later.
EDIT: To clarify the "opened" part, I meant since we opened the box it was in, we didn't open the Classmate itself. >_>
Crio not communitcating with Classmate! voteforandy1 General Forum 1 22-01-2010 21:50
Camera not sending image to Classmate? TPNigl Programming 14 22-01-2010 17:05
Dashboard not appearing on classmate railerobotics Programming 2 20-01-2010 15:42
Classmate not loading Dashbaord on bootup gokul Control System 2 13-01-2010 10:34
PWM cables not fitting GillSt.Bernards General Forum 4 16-02-2009 00:43
