Go to Post I think I just found a way to replace our entire robot drive team! (no big deal, they are graduating anyway!) :D - dlavery [more]
Unread 01-02-2010, 02:24
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
increasing flow rate to pnuematic cylinder
Hi, you guys probably already know about this, but we're pretty disappointed at the velocity of the pnuematic cylinders. I've heard that this is partially due to the diameter of the tubes.
Does anyone have any suggestions as to how to increase the flow rate to the cylinders?
Are we allowed to use tubing with a larger ID?
I've also read that some teams are using T fittings at the inlet of their cylinders. Is this legal?
Much appreciated!
Windell
Friction-increasing substances nayer247 Technical Discussion 15 29-01-2009 12:10
Increasing available program memory DanDon Programming 21 30-05-2005 17:00
Flow Switch question? Inert Entry Pneumatics 1 28-02-2005 16:22
White Paper Discuss: Increasing A/D Resolution Using Noise CD47-Bot Extra Discussion 7 12-10-2004 09:26
Flow rate / remaining pressure swabbie58 Pneumatics 5 11-02-2004 12:57
