Go to Post "Building the technology of tomorrow - sometime late tonight!" - dlavery [more]
Go Back   Chief Delphi > Technical > IT / Communications > 3D Animation and Competition
Unread 01-02-2010, 13:40
Jujuc92 Jujuc92 is offline
FRC #0069
Jujuc92 is an unknown quantity at this point
Smile Making Clothing! HELP!!!
Hello,
I was wondering if anyone knows a way to create a simple t-shirt and a simple pair of pants! I would rather not use my characters and bipeds with out their clothing!
Oh and I have looked at links for the lost and I have googled tutorials forever, and I have yet to find a simple way to make clothing!
Please Help!!!
I only have basic skills I am no expert!
Thanks!
Unread 01-02-2010, 15:42
rastermon rastermon is offline
FRC #0847
rastermon is an unknown quantity at this point
Re: Making Clothing! HELP!!!
Cloth modifier comes to mind, (I never used it). But you would still have to model your t shirt and jeans, then apply the cloth, defining your character as a collision object. Play with the settings to make sure it does not go through your character. Or just make them very basic (cylinders and such) and bone them along with your character (no cloth simulation).
Good luck
Unread 02-02-2010, 14:07
FRC #0069
thank you very much i will try that!!!
JC
Unread 02-02-2010, 17:31
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Team Role: Teacher
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
You know, until I realized this thread was about 3D animation, I was very confused.
"It's NOT Just A Robot Thing!"
Unread 02-02-2010, 20:24
rjbman's Avatar
rjbman rjbman is offline
Animator Dominator
FRC #2081
Team Role: Animator
rjbman is an unknown quantity at this point
ROFL
"Any sufficiently advanced technology is indistinguishable from magic."
-Arthur C. Clarke
Anything I make is indistinguishable from cave paintings.
-epic fail-
Unread 02-02-2010, 21:45
imp's Avatar
imp imp is offline
FRC #0675 (Tech High Phantom Robotics)
Team Role: Animator
Rookie Year: 2007
imp is on a distinguished road
You could also try making a box, using editable poly with extrude, delete the end faces and mesh smooth or relax everything to round it off. Fit it over the body figure and use the cloth modifier and it will hopefully work. no promises though I am a good animator in only the theoretical sense
Unread 08-02-2010, 13:53
Ben LaCount Ben LaCount is offline
FRC #1716
Ben LaCount is an unknown quantity at this point
You could model some clothing and apply the "Garment Maker" modifier to a "pattern" of clothing. The garment maker works with the cloth modifier to create a reasonable simulation of clothing as it should deform over an animated body. This process requires a little work, but it works nicely. If you go to the HELP menu in max and type in garment maker, it will give you a walk-through on how to use it. Typically garments can be added to a character after the character has been animated because the cloth needs to be "simulated" or deformed per frame. Give that a shot, or you can just model the clothes right on the character and normal map them just like they do for video games.
Ben LaCount
Autodesk Certified Instructor
Need help making water supertetelmanma 3D Animation and Competition 3 11-02-2007 19:42
Help - Making the autonomous mode razer Programming 5 31-01-2007 16:25
HELP!!!!!! LABVIEW IS MAKING ME MAD!!!! cdennisxlx2 LabView and Data Acquisition 2 21-03-2006 21:50
Making a Dongle - Pin 1 help DanL Electrical 6 05-03-2003 16:58
I need help w/ making an Invitational Matt Attallah General Forum 6 14-05-2002 19:48
