Gaming adapter power problem
Our team is having some trouble connecting our gaming adapter to the power distribution board. Where should we hook it up?
Re: Gaming adapter power problem
It plugs into the 12v DC socket next to the cRIO power socket.
We tried that, but it didn't work. Is there any way to tell which wire is + or -?
It sounds like you could use the power distribution schematic.
The wire with the white stripe is positive.
The white stripe indicates POSITIVE.
Wire it in reverse and the wireless adaptor will burn out. Of course, if you've already wired it backwards, then you probably need to buy a WET610N as a replacement. Last edited by Mark McLeod : 01-02-2010 at 21:45. Reason: Hastypickle isn't so hasty |
Whoops. I didn't have anything to check if I was correct so I added the "I believe" at the beginning. I should probably remember that for future information though. Thanks for correcting me.
That is incorrect. The wire with the white stripe is the positive wire.
Get the documentation from the http://www.usfirst.org/frccontrolsystem page. The information you want is on page 8 of the Chapter 3 document.
Note: it is the positive wire which bears the stripe. |
#10
We have successfully powered the wireless game controller. The wire with the white stripe is, indeed, the positive connection.
#11
Thanks! As it turned out, we did in fact fry it, but we got a new one and it's working great. Thanks!
| 2009 Gaming Adapter not working after reset | MartinB | FRC Control System | 4 | 25-01-2010 00:02 |
| Linksys WGA600N-RM Dual Band Wireless-N Gaming Adapter | westy92 | Control System | 2 | 20-09-2009 14:36 |
| Linksys Gaming adapter | Phoenix Spud | FRC Control System | 6 | 04-02-2009 01:01 |
| Fubar Gaming Adapter | Lord Byron | FRC Control System | 4 | 15-01-2009 17:43 |
| Gaming Adapter Orientation On Robot: Does it matter? | Tom Line | FRC Control System | 1 | 12-01-2009 12:48 |
