Go to Post We also indirectly benefit from those rookie teams having well-built and working drivebases. It helps raise the level of performance across the board, making for a better competitive environment. - Alan Anderson [more]
Unread 01-02-2010, 19:55
Paul West Paul West is offline
FRC #1072 (Harker Robotics)
Team Role: Leadership
Paul West is an unknown quantity at this point
Broken radio not replaceable
Hi. My team has a broken Linksys Dual-Band Wireless-N Gaming Adapter
(WGA600N). This is the only radio allowed by the FIRST rules. However, Linksys stopped making this adapter in favor of the WET610N Dual-Band Wireless-N Ethernet Bridge. FIRST did not respond to emails asking whether or not the new model is acceptable. The FIRST replacements page isn't useful, either, because the website of where to buy replacement radios is out of stock permanently. Any ideas would be useful.
Thanks =)
-1072
Unread 01-02-2010, 20:05
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Broken radio not replaceable
The FIRST blessed alternative is a WET610N
<R58> One KOP wireless bridge (either model WGA600N or WET610N) is the only permitted mechanism for communicating to and from the ROBOT during the MATCH. The signal output from the wireless bridge must be directly connected to Port 1 of the cRIO-FRC with an Ethernet cable. All signals must originate from the OPERATOR CONSOLE and/or the Field Management System, and be transmitted to the ROBOT via the official ARENA hardware. No other form of wireless communications shall be used to communicate to, from or within the ROBOT (e.g. radio modems from previous FIRST competitions and Bluetooth devices are not permitted on the ROBOT during competition).
Unread 01-02-2010, 20:07
johnr johnr is offline
FRC #0910
johnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond repute
hope this helps http://forums.usfirst.org/showthread.php?t=13924
Unread 01-02-2010, 23:03
Thanks.
Unread 03-02-2010, 13:29
schlegs's Avatar
schlegs schlegs is offline
Lead Mentor Team 1518
AKA: Kevin Schlegel
FRC #1518 (Raider Robotics)
Team Role: Coach
schlegs is an unknown quantity at this point
Where is the best place to buy a new wireless bridge?
Unread 03-02-2010, 16:00
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
The WET610n is widely available, either from most Best Buys or online. The best place would be the one that is the cheapest that gets it to you when you need it.
Unread 08-02-2010, 14:23
Frys has one for $89.99
Unread 22-02-2010, 10:49
Jason Law's Avatar
Jason Law Jason Law is offline
Team Captain
FRC #2834 (Bionic Barons)
Team Role: Mechanical
Jason Law is just really niceJason Law is just really niceJason Law is just really niceJason Law is just really niceJason Law is just really nice
Is the configuration (IP addressing to your team number) of the "newer" radio the same as the "older" radio?
Unread 22-02-2010, 10:54
Just Itinerant
If you have last year's WGA600N, then the default address is 192.168.1.250
If you have a new WET610N, then the default address is 169.254.1.250
Otherwise, you setup the FRC IP address the same, e.g., 10.xx.yy.1
Unread 22-02-2010, 23:17
Jason Law's Avatar
Team Captain
Thanks a lot! I was trying to use the old IP until I realized it might be a different set up...
Thanks again.
VEX Radio Range & Loss of Radio Fail Safe? Chris_Elston Programming 14 03-09-2008 09:13
2007 radio not working Doug Leppard Technical Discussion 2 19-01-2008 18:12
Help! Radio not working steve d Electrical 13 16-02-2007 20:00
Radio problems -- not archiver 2000 1 23-06-2002 22:23
Broken promises or BROKEN ROBOTS! archiver 1999 9 23-06-2002 22:18
