Holonomic issues
I have validated that the wheels are mounted correctly "x" from the top "o" from the bottom.
I have validated that we are sending in the correct vector in degrees. 0 for straight ahead. We can move forward with 0 and backward with 180 when motors on one side are inverted. But we have no ability to strafe. The motors are each side are fighting each other. When we change the motors so that none are inverted. We can strafe side to side with no issues, but we can no longer go forward or backwards. Check polarity on all the jags. Anyone have any ideas? seems like we are making a simple mistake. |
| Holonomic drive angle? | dwodrich | NI LabVIEW | 17 | 05-02-2010 09:39 |
| Holonomic vs Mecanum Help!! | kSniper | Technical Discussion | 10 | 25-03-2008 16:57 |
| Holonomic Programming??? | sknkmeistermatt | Programming | 2 | 12-02-2008 15:47 |
| Holonomic... | Greg Perkins | Technical Discussion | 2 | 02-02-2005 11:59 |
| holonomic drives | Max Lobovsky | Technical Discussion | 5 | 10-03-2004 21:31 |
