Go to Post Yup. Two world champs on one alliance, out in the quarterfinals. Only at IRI. - Norman J [more]
Unread 01-02-2010, 22:09
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Rookie Year: 2007
Robototes2412 is on a distinguished road
Crio does not accept new programs
Instead, it just spins the motor on port 1 at ~5% speed, weve even tried reformatting.
Help pls.
The code is just a dead simple make this motor go project
Unread 01-02-2010, 22:38
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Crio does not accept new programs
  1. What language?
  2. What are the steps you follow to download?
  3. Can you create a brand-new default program and download that?
  4. What do the many status lights on the Driver Station show?
  5. What do the many status lights on the Digital sidecar show?
  6. Possibly a description of how you wired your robot might help.
Unread 01-02-2010, 22:49
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Can you double-check your wiring? Odd behavior on the PWM outputs is often explained by not having the Digital Sidecar powered properly from a 20 amp breaker.
Unread 02-02-2010, 18:39
1 * 4 != 14
Rookie Year: 2007
We did make sure everything was wired goodwise. We are using java. heres the code:
Code:
/* Copyright (c) FIRST 2008. All Rights Reserved.                             */
/* Open Source Software - may be modified and shared by FRC teams. The code   */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project.                                                               */
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.*;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the SimpleRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
public class EEARGH extends SimpleRobot
    Joystick xbox = new Joystick(1);
    Jaguar motor = new Jaguar(1);
    Jaguar otherMotor = new Jaguar(2);
     * This function is called once each time the robot enters autonomous mode.
    public void autonomous() {
	while(isEnabled()) {
           motor.set(1);
           Timer.delay(5);
	   motor.set(0);
	   Timer.delay(5);
     * This function is called once each time the robot enters operator control.
    public void operatorControl()
        getWatchdog().setEnabled(true);
        getWatchdog().feed();
        //boolean isReversed = false;
        double speed = xbox.getRawAxis(2);
        //motor.set(0);
        while(isOperatorControl())
            otherMotor.set(-speed);
sometimes the motor just spins creepily by itself, without user input.
Code deploys but does not save to cRIO Bill Taylor NI LabVIEW 11 15-02-2012 20:30
Downloading code: Netbeans does not reset cRIO ellisk Java 8 31-01-2010 19:02
Imaging Tool does not find cRIO aeasson FRC Control System 2 10-01-2010 20:39
cRIO Does Not Communicate, Yet Can Be Pinged and Re-Imaged 1951-44U FRC Control System 7 15-12-2009 21:25
Crio network light does not light when camera plugged in Bongle Programming 16 16-01-2009 11:00
