Go to Post Weren't you ever told Canada is backwards from the US? - Alex Cormier [more]
Unread 02-02-2010, 02:10
nadavsen2 nadavsen2 is offline
FRC #2231
nadavsen2 is an unknown quantity at this point
something about pressure
There is any way to open the piston only half way? and without timer or something like that. I mean with different psi everytime..
tnx
Unread 02-02-2010, 04:20
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
Re: something about pressure
If you use two solenoids, you can use a lower pressure regulator and have to separate working pressures, let's say you have one at 30 psi and the full 60 psi on another. They use to (still do?) include adjustable pressure regulator.
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Unread 02-02-2010, 08:08
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
As long as the pressure on one side of the piston is higher than the other side of the piston, the piston will move until something causes it to stop or the pressure on both sides of the piston is equal.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 02-02-2010, 08:27
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Dad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud of
If you are using them to retract (or compress) a spring, different PSI will result in different lengths.
If you need multiple 'fixed lengths', use multiple cylinders & valves.
If you need proportional/adjustable lengths, you can use two solenoids. 1 double to move the cylinder back and forth, and a single connected to the exhaust of the first. Opening the second solenoid will allow motion.
http://www.chiefdelphi.com/forums/sh...2&postcount=11
Does the Norgren Pressure Regulator show working pressure or stored pressure? Madison Pneumatics 7 14-02-2008 17:40
Clean Water - Something to Think About Chris Fultz General Forum 28 24-07-2004 20:33
pic: Something to think about... CD47-Bot Extra Discussion 27 11-07-2004 02:27
Something to Talk About- Funny Stories archiver 2000 1 23-06-2002 22:06
Question about Pressure Switch Randy_Ai Technical Discussion 1 30-01-2002 18:29
