Go to Post this is a TEAM effort...teach them something. Who knows, with a little luck, you might just learn something yourself! - Nuttyman54 [more]
Unread 02-02-2010, 08:29
zebrabots zebrabots is offline
FRC #2909
zebrabots is on a distinguished road
Problems with Tank Mode and Wireless Connection
We have programmed our robot to function in Tank mode, however after uploading the new program we are only allowed to operate in Arcade mode.
Also, we are having problems connecting wirelessly. We have reset and reconfigured both the wireless router and the gaming adapter. Any suggestions?
Unread 02-02-2010, 09:13
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Problems with Tank Mode and Wireless Connection
For help with the code, either post a picture or better yet the vi itself.
I helped a rookie team that had wireless troubles due to unexpected settings on the bridge. Check the other settings not mentioned in the Control System manual to disable any extra security and verify your SSID is correct. Since the wired operation works, just concentrate on the wireless settings and compare the router and bridge.
Unread 02-02-2010, 10:43
JohnFogarty's Avatar
JohnFogarty JohnFogarty is online now
FTC, I have returned.
AKA: @doctorfogarty @GarnetSq
FTC #11444 (Garnet Squadron) & FRC#1102 (M'Aiken Magic)
JohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond repute
tank drive was a problem, i had to rewrite to Labveiw code in the begin and tele-op vi's completely from the ones that come with a new project i will post one that i have known to work.
John Fogarty
2010 FTC World Championship Winner & 2013-2014 FRC Orlando Regional Winner
Mentor FRC Team 1102 M'Aiken Magic
"Head Bot Coach" FTC Team 11444 Garnet Squadron
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632
2013 FTC World Championship Guest Speaker
Unread 03-02-2010, 04:05
cilginbilgin cilginbilgin is offline
FRC #2905
cilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the rough
We have also same problems with wireless connection and programming. If you can't make the robot code green in driver mode you have not to close the Labview Imageing Tool while you are working on it in developer mode.
Unread 03-02-2010, 18:49
Download Help Team.zip from FileFactory.com
John Fogarty
cRio connection and license problems (windriver) yabberyabber FRC Control System 5 30-01-2010 21:19
Wireless Connection Problem!!! EagleS!! General Forum 5 28-01-2010 07:56
Jaguar and wireless problems. Team_2547 FRC Control System 1 26-01-2009 16:54
Wireless Connection on Pocket PC - AEGIS and Odyssey sanddrag IT / Communications 2 07-01-2005 15:51
Major problems with tank tread drive Lord Nerdlinger Technical Discussion 13 23-02-2004 21:15
