Go to Post Just think outside the box but inside the 28" X 38" X 60" rectangular prism and you may come up with a solution. - Pavan Dave [more]
Unread 02-02-2010, 14:47
Team1824 Team1824 is offline
FRC #1824
Team1824 is an unknown quantity at this point
error in Autonomous independent when using "run as startup"
Every time our team tries to deploy the labview code to the cRIO via "run as startup" I get an error saying that several VIs are part of a Real-Time Startup application and all VIs on the target will be closed if we continue. Autonomous independent is one of these. If I just hit okay the code will deploy and run as it should, but the autonomous independent does not work.
What should I do???
Team 1824
Unread 02-02-2010, 14:55
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Re: error in Autonomous independent when using "run as startup"
Hit "OK". This is just telling you that you already have code running on the CRIO - it's the code you deployed last time around. This is a bit like the Windows warning - "Do you want to overwrite this file".
It's technical and scary looking, but harmless since you already know you want your new code on the Crio and not your old code.
Unread 02-02-2010, 15:07
FRC #1824
So this is definitely not the reason my code is not working? it seems that the code is set up properly but nothing happens when I tell the driver station to use the Autonomous code.
Team 1824
Unread 02-02-2010, 15:39
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
What you described in the first post is not an error message. It's a warning that you're about to halt the program that is presently running in the cRIO so that you can replace it with a new program.
If you want help in understanding why your Autonomous code isn't working, show us what you have.
Unread 02-02-2010, 15:52
FRC #1824
okay here is the autonomous code.
ID:	8472  Click image for larger version
Team 1824
Unread 02-02-2010, 19:40
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Have you checked that Robot Main.vi actually calls Autonomous Independent.vi?
Unread 03-02-2010, 09:02
Check Begin.vi to see if the enumeration selector is set to run the Autonomous Independent or simply the iterative.
Also, leave the Auto Independent window open and run your code from the project by pressing the run button on Robot Main. You should see the Autonomous VI called, see the run arrow on the autonomous Independent window fill in, you could set a break point, add probes, etc.
Determine whether the Auto is being called, but isn't behaving properly, or is not being called.
Greg McKaskle
Unread 03-02-2010, 09:13
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
What do you expect Autonomous independent to do?
Unread 03-02-2010, 12:52
hamosad1657 hamosad1657 is offline
FRC #1657
hamosad1657 is an unknown quantity at this point
When you finished the code building, did you saw a "Building is complete" message?
When my team was beta tester, we met a problem with the Autonomous independent during the code building, and we solved it successfully. So give more details about the error
Good night from Israel
Unread 04-02-2010, 16:02
FRC #1824
Yes the autonomous independent is being called in the begin.vi. What the code is supposed to do is use the default auto independent code to center the target and then move forward. However the camera is not hooked up so is that the problem? I was assuming that it would simply skip the camera code and go right to the movement code but I guess that might not be the case...?
Team 1824
Unread 04-02-2010, 17:24
Rookie Year: 1997
It won't move unless it sees the target.
[FTC]: Autonomous Deployment Error "1003" neblixsaber FIRST Tech Challenge 2 28-12-2009 12:55
Using Sensors in Autonomous Independent Felipe Sagui NI LabVIEW 2 27-01-2009 17:25
cRio losing connection when "run as startup" mgurgol Programming 2 12-01-2009 12:18
Will 3ds Max 2009 run on "regular" Windows XP? Kevin Thorp 3D Animation and Competition 3 12-11-2008 22:07
how tall is the ramp when in "up" and "balanced" position??? archiver 2001 1 24-06-2002 00:54
