Go to Post Iteration is something everyone can do. - [more]
Unread 02-02-2010, 16:46
shaggy0928 shaggy0928 is offline
FRC #1339
shaggy0928 is an unknown quantity at this point
Jaguars Blinking Red
We are using a tank drive system with one motor on one jaguar. The problem we seem to be having is some kind of current overload. Whenever we attempt to run the motor, the jaguar almost instantly locks up and blinks red for a few seconds, however if you EXTREMELY slowly ramp up the speed from 0-100% you can avoid this lock up.
The motor is not currently connected to anything, as we were thinking strain was causing it to lock up, but even without driving anything, we encounter the same problem.
If anyone knows any possible causes of this problem or solutions, the help would be extremely appreciated.
Unread 02-02-2010, 17:20
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Jaguars Blinking Red
Are all your electrical connections tight and your battery charged?
Unread 02-02-2010, 17:50
Joe6391 Joe6391 is offline
Joe
AKA: Joe
FRC #1361
Joe6391 has a spectacular aura aboutJoe6391 has a spectacular aura aboutJoe6391 has a spectacular aura about
When we encountered this problem, it was a low battery.
Try swapping out or charging the battery and make sure to check that all your connections are secure.
Unread 02-02-2010, 20:06
FRC #1339
Alright, I'll try both of those things, thanks guys.
Unread 03-02-2010, 20:56
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
The symptom you describe is the Jaguar going into current protection. If the jaguar remains inoperative with the Red LED for about 4 seconds, this is the wait time for the Jaguar to reconnect after a fault. If this is what is happening in your robot, it is a good indication that the CIM motors are geared so high that start current is at or near stall current for a length of time. If this is the case, a wise designer will change the gear ratio to slow things down and keep the CIM away from stall.
Al
WB9UVJ
www.wildstang.org
________________________
Jaguar Red Blinking Light RMS11 Programming 4 23-02-2009 09:18
blinking program light tseres Control System 3 08-04-2007 17:45
Program State red blinking Generalx5 Programming 11 05-04-2007 19:01
Blinking Red Light teh_pwnerer795 Programming 8 21-12-2006 23:13
Program light is blinking red elsacr FIRST Tech Challenge 1 27-02-2006 10:23
