driver station update
we are trying to get the camera working but in order to do that we need to update the driver station first. but we do not know how to update the driver station.
can you guys help me on this problem? ![]() |
Re: driver station update
Run the mandatory Driver Station update found here
http://usfirst.org/roboticsprograms/....aspx?id=10934 Be sure to uninstall before you reinstall. EDIT: You also need the .dll after you update. |
thanks for the information.
using your information, we are able to run the camera on the driver station. thanks again |
| driver station firmware update | tanguma26 | Programming | 1 | 14-02-2009 19:53 |
| driver station firmware update | bobbyt14 | Programming | 15 | 14-02-2009 15:05 |
| Driver Station Firmware Update 2009-01-22c1 | Mark McLeod | FRC Control System | 4 | 09-02-2009 11:52 |
| Driver Station Update | ExarKun666 | FRC Control System | 8 | 15-01-2009 10:39 |
| Driver Station firmware update failure | ofshea | FRC Control System | 8 | 13-01-2009 11:35 |
