Go to Post However, as a philosopher, while you need math, you can probably talk your way out of it. - sciguy125 [more]
Unread 02-02-2010, 21:21
MrFixIt2719 MrFixIt2719 is offline
AKA: Tarik Deland
FRC #1528 (Monroe Trojan Robotics)
MrFixIt2719 is a name known to allMrFixIt2719 is a name known to allMrFixIt2719 is a name known to allMrFixIt2719 is a name known to allMrFixIt2719 is a name known to allMrFixIt2719 is a name known to all
Picking Two other Robots off the ground
Do you think it would be a good idea to design your robot to instead of relying on two robots to try and hang from you but to design a way to lift the other two up with you?
Formula for Lifting Two Other Robots Jacob Paikoff General Forum 2 10-01-2010 00:09
Average height off the ground??? KcTechTeacher Technical Discussion 11 10-01-2007 22:23
Who is picking up from ground? sanddrag Rules/Strategy 15 10-02-2006 09:55
Emergency: PID with Wheels Off the Ground Rick TYler Programming 9 07-02-2006 11:37
hanging off off other robots that are hanging off the horiz bar Andrew Dahl Rules/Strategy 15 12-01-2004 19:14
