How to get camera to move?
For some reason, I can't find this. What methods are used to make the camera servos move? What are the method names and arguments? Is there anywhere I can find them? Thanks guys!
Re: How to get camera to move?
You speak of "methods" and "arguments", so I will assume you're using C++. The way to control a Servo is with the Servo class.
Look at page 64 of the C Programming Guide for FRC.pdf file. It is installed by default in the C:\windriver\docs\extensions\FRC directory. |
I don't think the circular target lends itself well to using the servos to search for the target. |
If using Java look up the set methods in the Servo class in the Java docs.
| Camera - how to get out of B&W? | pgaston | Technical Discussion | 9 | 19-12-2008 09:00 |
| Off-Season Challenge - I Like to Move It, Move It! | Kevin Thorp | 3D Animation and Competition | 11 | 03-11-2008 16:04 |
| Where do I begin to get the robot to move using the camera? | Ianuser | Programming | 10 | 16-02-2007 17:55 |
| How do I get distance between Camera and the target? | sjung9442 | Programming | 5 | 27-01-2006 09:44 |
| how does your robot move? | gondorf | Technical Discussion | 9 | 16-01-2006 16:36 |
