Go to Post If a team wants to cheat then it does nothing but give them a bad cloud hanging over their own heads. - Jon K. [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Unread 03-02-2010, 02:01
FRC4ME FRC4ME is offline
FRC #0339
Rookie Year: 2007
FRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant future
Bricked black Jaguar after bad firmware update
Okay, so today we were really excited to finally get the CAN working and began the process of flashing all of our Jaguars. We're using a black Jaguar as a bridge between a PC serial port and the CAN interface.
Everything was going well, until I accidentally flashed the grey firmware onto the black Jaguar (I was assigning a new ID to a grey one further down the line, then ran the firmware update without realizing the active board resets to the lowest ID (the black Jag in our case) after an assignment). After this, the LED doesn't light up and the black Jag won't respond to any commands.
The real problem is, we have tried all of the common solutions to this problem. We tried downloading the correct firmware from the bdc-comm command line utility. We tried downloading to ID 2 (what we had last set it to) and ID 1 (the default); neither work. The download appears to progress but takes forever (about an hour), and after it reaches 100%, the Jaguar still has no light and does nothing.
We also tried using the bdc-comm boot command, which is supposed to send firmware to a Jaguar if you boot it while holding down "the button" (I assume this means the user button). When we do this, bdc-comm seems to respond; a huge amount of "." characters suddenly fill the command line window. But no download starts and nothing happens to the Jaguar.
Is there anything else we can try? I don't understand why the normal solutions to this problem aren't working for us. Is there a way to broadcast firmware (send to ID 0)? Any way to reset the Jaguar to factory defaults?
Thanks for any assistance
Go directly to queue. Do not pass pit.
Trouble getting BDC-COMM to see the black Jaguar Randy Forgaard CAN 5 27-01-2010 09:14
Black Jaguar RS232->CAN - anyone? oddjob C/C++ 12 22-01-2010 16:25
Release Announcement for the MDL-BDC24 (Black Jaguar) JDNovak FRC Control System 2 16-12-2009 18:13
The Black Jaguar David Doerr FRC Control System 5 25-11-2009 15:43
Firmware update Cuog Programming 2 21-02-2006 20:28
