Go to Post To quote Harrison Ford: "Never tell me the odds". - [more]
Unread 03-02-2010, 02:30
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
Team 753 short and wide mecanum over the bump
The title really says it all, here's the video http://www.youtube.com/watch?v=z--8Pb5tb1c
Jason
Unread 03-02-2010, 23:51
PaW's Avatar
PaW PaW is offline
AKA: Paul W
FRC #1899 (Saints Robotics)
PaW has a spectacular aura aboutPaW has a spectacular aura about
Re: Team 753 short and wide mecanum over the bump
Nice save at the 1:40 mark! Speed control and driver practice will be key to avoid an "end over".
Unread 04-02-2010, 00:22
V_Chip's Avatar
V_Chip V_Chip is offline
Back in action.
AKA: Victor
FRC #0175 (Buzz Robotics)
V_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud ofV_Chip has much to be proud of
The ability to sit at the top of the hump and move laterally has the potential to be a great defensive advantage
Unread 04-02-2010, 00:27
yes they will, we are actually looking into putting an accelerometer on it to automatically transition us back onto the flat ground.
Jason
lenny8's Avatar
lenny8 lenny8 is offline
Aww Yea
AKA: L-Deezy
FRC #1018 (Robodevils)
Team Role: Coach
Rookie Year: 2007
lenny8 is a splendid one to beholdlenny8 is a splendid one to beholdlenny8 is a splendid one to beholdlenny8 is a splendid one to beholdlenny8 is a splendid one to beholdlenny8 is a splendid one to beholdlenny8 is a splendid one to behold
not to be mr. negative bot id be surprised if u don't tip at least once during regionals.
Learn something, Know Something, Do something
Unread 04-02-2010, 00:29
V_Chip's Avatar
Back in action.
AKA: Victor
You might look into lowering your CG. However that will affect your entire configuration it seems
Unread 04-02-2010, 00:39
CraigHickman
Posts: n/a
Until a traction bot slams into a strafing robot and flips it. Keep in mind that Mecanums are insanely maneuverable, but can be pushed around by almost any other drive system.
Especially tracks.
Unread 04-02-2010, 00:43
V_Chip's Avatar
Back in action.
AKA: Victor
However the other team may risk the consequence of a penalty. . . IF the contact is outside of bumper perimeter.
Good point though
Rion Atkinson's Avatar
Rion Atkinson Rion Atkinson is offline
The CAD Guy
Rion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond repute
Originally Posted by CraigHickman View Post
Until a tracked bot slams into a strafing robot and flips it. Keep in mind that Mecanums are insanely maneuverable, but can be pushed around by almost any other drive system.
Especially tracks.
That's where the fast eye comes in handy. And hand...
Basically, as long as you can see that it is coming, it should be to much of a problem.
‎‎"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. -Albert Einstein
Start Something
Email - rionatkinson@gmail.com
Skype - Rion.Atkinson
Unread 04-02-2010, 00:44
The CG will be significantly lower in the final bot, the electronics board is going to be at about the level of the bottom of the transmissions and there is a scoring mechanism going in as well. The electronics board was just put where it is to get our bot up and running so we can get some practice driving it.
Who can figure out what the plywood came from?
Jason
Unread 04-02-2010, 00:47
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
I'm a little concerned by a couple of the hops your electronics rig took. I'd recommend restraining the battery a bit more, and giving the delicate parts on the cRIO some overhead protection in the event your driver or software doesn't pull off the save next time. I realize you're testing, but nothing on that board is a cheap replacement. If you roll the robot and weight ends up on, for example, the analog breakout, it will bend and/or break.
CraigHickman
Posts: n/a
Good point though
The bumper zone does not apply when on the bump.
Ah, but as long as a defender is causing a team to focus on anything other than scoring, their job is successful.
Besides, all it takes is one solid push to tip a robot on the ramp over.
Jason-
Do you guys happen to have any footage of the bot driving around in the open? I always love seeing Mecanums systems drive, as they're always so fluid looking when they translate around.
Unread 04-02-2010, 01:01
As you may have noticed, we did have people running back and forth to help keep the bot from tipping. We actually did tip the bot during this testing (the spotters weren't paying enough attention), but luckily the only damage was one of the screws on the D-sub connector got bent. We are done testing over the bump until everything is in its final place.
sorry, i don't have any good footage of it running around in the open.
Jason
Unread 04-02-2010, 01:02
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
Looks like the robot almost flipped because it was put into reverse when the back end was up in the air.
  #15   Spotlight this post!
Unread 04-02-2010, 01:41
Fe_Will's Avatar
Fe_Will Fe_Will is offline
AKA: Will
FRC #0955 (CV Robotics)
Fe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud of
Especially tracks.
We'll see how the tracks vs mecanum ends up Feb. 20th. I'm looking forward to seeing that little creation you've had a hand in. Until then, I like what 753 has been gracious enough to post (minus the near tip).
"It is the mark of an educated mind to be able to entertain a thought without accepting it." -Aristotle
FRC488 Driving Over the Bump Madison Robot Showcase 27 03-02-2010 04:40
2481 Drives Over the Bump with Mecanum Wheels kylelanman Robot Showcase 13 02-02-2010 00:53
DiscoBots Omni Drive over Bump lynca Robot Showcase 26 20-01-2010 00:51
Over the bump or under the tower quinxorin Rules/Strategy 44 18-01-2010 14:17
Image Discuss: Team 753 Working on the Stacker CD47-Bot Robot Showcase 2 22-02-2003 01:05
