"VxWorks6x_10.32.42.2 (Registry localhost)"
Here is the error report from trying to connect to the cRIO:
This occurs on a physical machine without admin privilages and on a virtual machine with admin privilages. Has not been tested on the netbook supplied by FIRST. |
Re: "VxWorks6x_10.32.42.2 (Registry localhost)"
Is the cRio powered up, running, and properly connected (via router or not) to the PC? Can you ping the cRio from the PC on which you're running Workbench? |
Have you followed the "Getting Started with C++" Manual here:
http://first.wpi.edu/Images/CMS/Firs...artedWithC.pdf I received similar errors until realized i had not selected the Kernel image as discussed on page 6. Good Luck! Last edited by Tom Schindler : 04-02-2010 at 11:18. |
I have read and followed it to the letter.
I still get the same results. I'll try again though... Edit: I tried pinging the device via the usb chord and it timed out. What could this mean? Last edited by z.s.tar.gz : 03-02-2010 at 17:33. |
I'm just giving my two cents here, but could it be possible that the network setup on your virtual machine leaves something to be desired? If it pings without response, there is only one thing that does that: it is not connected. Lack of admin rights on a physical computer can do this too, since you need to change network settings.
I just tried it on the FIRST netbook, and I get similar results even though I have admin rights and the firewall is turned off.
Is there anything else I have to do to set it up that's independent of windriver? If so, I haven't done it. Edit: I think I have the wrong thing. The cRIO is the little microcontroller right? Or is it the thing that goes on the actual robot? Last edited by z.s.tar.gz : 03-02-2010 at 18:03. |
The cRIO is the long, heavy rectangular box that the 'cards' slot into. Has a lower section that has some dip switches, a serial port and two ethernet ports.
I would suggest going back to the beginning and making sure you didn't miss anything. Work through this, and then this. Start a new workspace to do this, rather than try persevere with what you have. When you have got everything working successfully, and if time permits, then go back to your current workspace and try to figure out what was different. |
Thank you, we have it figured out now. It was just confusion on how the system worked that was our problem.
| Championship Event - Where the "Random" Match Sorting Really "Shines" | Travis Hoffman | Championship Event | 57 | 19-04-2007 08:06 |
| New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" | Jessica Boucher | Team Organization | 0 | 10-08-2005 10:55 |
| "Thunderbirds" Vs. "Team America" Which one will rule the box office? | Elgin Clock | Chit-Chat | 3 | 07-09-2004 19:53 |
| Conflict between "Initialize_Tracker()" and "pwm13 & pwm15"? Kevin? | gnormhurst | Programming | 3 | 22-02-2004 02:55 |
| how tall is the ramp when in "up" and "balanced" position??? | archiver | 2001 | 1 | 24-06-2002 00:54 |
