Go to Post you must do whats best for the company...not yourself. - Greg Perkins [more]
Unread 03-02-2010, 14:36
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
PSOC Understanding
We are just trying to figure out the pinout to our code and exactly how that works with the PSOC Board. . . After looking at all of my known resources I could not find any examples.
We are looking at hooking up a Potentometer, couple 2 position switches, and couple LEDs.
We hooked up the PSOC board to the classmate and downloaded the FRC_v2.hex file using the PSOC programmer and it shows the green light on the Dashboard of driver mode.
Looking at the pinout of the Cypress PSOC board on http://www.usfirst.org/roboticsprogr....aspx?id=10934 I miss where you set if its a digital output or digital input?? Is this set in Windriver? (we are using C++). (I also see the documentation at http://www.cypress.com/?rID=38235)
Can someone post an example on how to hookup and program an analog, digital output, digital input to PSOC Board.
I THINK. . .
Analog 1 is P0_0 and value can be retrieved from driverstation->GetAnalogIn(1)
Digital Input 1 is P4_4 and value can be retrieved from driverstation->GetDigitalIn(1)
Digital Out = ?!?!?! do you have to designate that digital channel 2 (P4_5) is out somewhere??
I just don't want to start hooking switches, LEDs, and pots up without knowing the hardware ahead of time :-)
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 03-02-2010, 15:03
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: PSOC Understanding
You can change the pin setting from the Driver Station IO tab.
On the tab click the "Configure..." button (bottom left).
The matching pin identifiers are there, too.
On the popup select Enhanced, choose your pin settings and OK.
PSOC Interface Card Lafleur Technical Discussion 4 09-02-2010 13:26
PSoC black magic nathanww FRC Control System 2 23-01-2010 21:41
Understanding blob size Bomberofdoom Programming 5 03-02-2007 18:37
Memorandum of Understanding (MOU) KathieK Team Organization 0 03-01-2007 12:43
Understanding engineers Katie Reynolds Chit-Chat 0 27-02-2004 18:04
