Go to Post Don't over analyze every possibility. Studying a problem too much doesn't help any more than not studying it enough. - dlavery [more]
Unread 03-02-2010, 16:21
rsegrest's Avatar
rsegrest rsegrest is offline
@ least I'm OVER the rock THIS time
FRC #2582 (PantherBots)
Team Role: Coach
rsegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant future
Pneumatics Testing...with code or direct to power?
As posted in a different thread we are having trouble with our pneumatics. Currently we have our pneumatic system directly wired to a battery. When we attempt to activate our solenoids by energizing them they do not operate. When we activate our solenoids manually they work. As we have read through posts we notice many people stating that you really need to connect the entire system to your robot (cRio) and run code on them to determine if they are working. Should we go ahead and connect everything to the robot to run test code on the solenoids or should we leave them as they are and continue to test them as we have been?
I know this sounds like a newb question but we have only used pneumatics once (two years ago) and so do not have a super clear understanding of them.
Impossible is just a big word for small men who find it easier to live in the world they've been given than to explore the power they have to change it. Impossible is not a fact. It's an opinion. Impossible is not a declaration. It's a dare Impossible is potential. Impossible is temporary. Impossible is nothing.
~ Unknown
Testing pneumatics? chadr03 Pneumatics 6 03-02-2010 21:06
Programming Direct drive with Direct (car like steering) tuna.and.cheese Programming 2 18-01-2009 11:26
Code Violation when testing chris_chen Programming 0 24-01-2006 20:28
Direct 7.2v power from the wall... Ferazel2001 Electrical 1 31-01-2004 17:49
