Go to Post Why not go the safer route? Use the robots to play Magic the Gathering. - kamocat [more]
Unread 03-02-2010, 19:12
chahalaman13 chahalaman13 is offline
FRC #3053
chahalaman13 is an unknown quantity at this point
Arrow How to deploy a custom vi??
I made a vi using the blank vi... but i cannot deploy it onto the cRIO because i cannot set the ip address... i need to know how to create a .lvproj of it..(in other words a project of it) so that i can set the designated ip address and deploy it...
thanks for any help..
Unread 03-02-2010, 19:56
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
Team Role: Coach
Rookie Year: 1996
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Re: How to deploy a custom vi??
Read through the manual.
http://usfirst.org/roboticsprograms/....aspx?id=10934
Unread 03-02-2010, 20:47
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
While you can create a new project for it, I imagine that you are missing almost everything you need to get it actually running on the cRIO, such as, starting communications with the Driver Station.
Downloading it to the cRIO is unlikely to result in any response at all.
However, from a new vi you can create a new project by going to Project ->New Project.
What you'll get is a new project for your PC. The cRIO would have to be added as a target.
I would suggest instead that you integrate your new vi with a default Robot Project instead.
That has everything you need to run on the cRIO.
One way to do that is to save your new vi, then create or open a default Robot Project, right-click the cRIO target and choose Add -> File...
How to set up custom dashboard for auto start Kevka Programming 11 28-01-2010 18:46
How to make a custom OI switch box Neurovirus Control System 2 25-02-2008 20:49
How to build a Custom CNC Bill_Hancoc Technical Discussion 28 23-08-2006 17:13
How to create a custom operator interface box? JWilliams101 Control System 9 27-02-2005 23:13
how to create custom interface _GP_ Technical Discussion 1 18-01-2004 21:24
