Go to Post I think he GDC is just rick-rolling all of us. - z_beeblebrox [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 03-02-2010, 20:08
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
Rookie Year: 2007
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
New BDC-COMM Version 88
Hello everybody,
There is a new version of BDC-COMM on the Jaguar Microsite. The current version is now version 88.
There is no update to the Jaguar Firmware, both are still 87.
The new version of BDC-COMM has an added feature to recover a "bricked" Jaguar. The cause for this is flashing the wrong firmware; (Gray) Jaguar firmware on a Black Jaguar and vice-versa.
So, your Jaguar LED does not light up when you give it power after a firmware update... here is what you do:
1) Make sure that the messed up Jaguar is the only messed up one on the network.
2) If you've messed up a Black Jaguar, connect it to the computer with your RS232 cable. If you've messed up a Gray Jaguar, use a working Black Jaguar to connect to the computer, and connect the non working Gray Jaguar to that working Black Jaguar.
3) Power on the Jaguar(s).
4) Open bdc-comm-88.exe. It should automatically connect and enumerate any working Jaguars on the network. If there are none, don't worry.
5) Go to File->Recover Device and select the correct firmware. Be sure to read the warning!
6) Click Update. If all goes well, your Jaguar should start blinking after the update.
Please spread the word about the new version.
Good luck!
-David
Unread 03-02-2010, 23:25
erichahn525 erichahn525 is offline
FRC #0619
erichahn525 is an unknown quantity at this point
Re: New BDC-COMM Version 88
Thank you very much, I will try this as soon as I CAN.
Unread 03-02-2010, 23:37
FRC4ME FRC4ME is offline
FRC #0339
Rookie Year: 2007
FRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant future
We just tried this and, unfortunately, it still didn't work. We get an "unable to contact bootloader" error. At this point I think we're just going to have to get a new Jag. Was worth a try, though!
Go directly to queue. Do not pass pit.
Unread 04-02-2010, 11:50
computerish computerish is offline
FRC #0619
computerish is an unknown quantity at this point
Is the Recover Device feature a GUI version of the boot command or does it make furthur efforts to unbrick the jaguar?
Thanks!
Unread 04-02-2010, 12:07
AKA: David Yanoshak
Rookie Year: 2007
This is a different feature than the boot command. It pushes out firmware to any Jaguar stuck in the bootloader regardless of ID. This is why it is important to recover one "bricked" Jaguar at a time. If there are more than one on the bus, you can really brick your Jaguar and the only way to recover would be use a JTAG programmer or replace the Jaguar (this might be why some teams cannot get recover to work).
The Jaguar firmware detects the hardware it is deployed on. If the firmware doesn't match the hardware, it will branch to the bootloader (no LED, so it looks bricked) and wait for an update.
-David
Unread 13-02-2010, 22:04
JasonStern JasonStern is offline
Mentor
FRC #1123 (AIM Robotics)
JasonStern is on a distinguished road
Is it possible to use the BDC-COMM tool on a pure CAN network? We only have Gray Jaguars and are using the 2CAN adaptor. Thanks!
Que será será
Unread 13-02-2010, 23:07
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Rookie Year: 2010
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
as far as I know the only way to interface with a 2CAN network is the web interface of the 2CAN. I might try to link the 2CAN comms and the serial plugin to allow BDC-comm with 2CAN, but our team is using a black jag so I can't test if it works
Unread 17-02-2010, 10:02
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
What exactly would you like to do?
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 17-02-2010, 11:45
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
I think he wants to update the jag firmware using the 2CAN.
Unread 17-02-2010, 11:49
He does not need BDC comm for that he can do it via the 2CAN.
Mike Copioli
Unread 19-02-2010, 20:22
Mentor
We just managed to brick two of our Jags updating the firmware to 89 via the 2CAN, so accessing the recover function would be nice. (The lights no longer turn on.)
It would also be nice to be able to use the tool for troubleshooting purposes and to try different PID values.
Thanks,
Jason
Que será será
Unread 20-02-2010, 00:44
Thanks,
Jason
These features will be avaiable in the 2CAN web dash in future releases. We just have not had a chance to make these changes. In the mean time I do not see any reason why you could not connect bdc com to a black jag that is on the CAN bus.
Mike Copioli
Unread 20-02-2010, 11:40
Mentor
We would do that if we had a black jag
We will be at the DC Scrimmage today, so we will try to find another team there with a black jag we could borrow.
-Jason
Que será será
Unread 22-02-2010, 12:48
Mentor
We forgot to to recover our Jags at the Scrimmage :-(. Is there any other way to recover them without a Black Jag?
Que será será
  #15   Spotlight this post!
Unread 25-02-2010, 15:13
Try loading the firmware again using the 2CAN interface. Make sure that the problem Jag is the only one connected to the CAN bus. I have noticed that once in a while the firmware update does not take the first time and the Jag gets stuck in bootloader(no LED). A re-flash after a power cycle has always fixed this for us. If this does not work then you may need to re-flash the bootloader using the JTAG interface.
Mike Copioli
Where to find BDC-COMM utility? rrossbach Control System 5 31-07-2011 00:43
BDC-Comm Problems when setting jaguars up for CAN LeelandS Programming 12 02-02-2010 16:00
Trouble getting BDC-COMM to see the black Jaguar Randy Forgaard CAN 5 27-01-2010 09:14
New version of FIRSTclipse: 0.0.3 Astronouth7303 Programming 8 18-02-2007 21:06
New version of WPILib BradAMiller Programming 26 27-01-2007 15:49
