Go to Post This is a pure blooded, man and machine versus man and machine, brain versus brain, driving skill challenge. - Andy Grady [more]
Unread 02-03-2010, 08:20 PM
Imadapocalypse's Avatar
Imadapocalypse Imadapocalypse is offline
The Walking Contradiction
AKA: Bryce Ribucan
FRC #2443 (Blue Thunder)
Team Role: Leadership
Imadapocalypse is an unknown quantity at this point
Send a message via AIM to Imadapocalypse
Reticle for camera
Okay so us here at team 2443 have figured out how to make the camera work. We just ran the CircleTrackerDemo and saw that it works just fine. We were wondering how the demo is able to draw on the camera image. The team wants to find a way to make a reticle for manual aiming.
The needs of the many out-weigh the needs of the few and the one
Unread 02-03-2010, 09:26 PM
Re: Reticle for camera
The functions for drawing into the image are in the IMAQ palette. The code on the cRIO isn't doing the drawing, though, because typically nobody watches the images. Instead, the info from the ellipse detection is shipped back to the dashboard, and the dashboard draws the annotations of the line and ellipses.
If you are using LV, open up your own dashboard template from the Getting Started window, and look at the top loop. It clears the annotations, then draws the lines in a subVI using polygons, and then draws the blue line. There is a whole palette for the shapes including text.
Greg McKaskle
Unread 02-04-2010, 02:28 AM
AKA: Bryce Ribucan
you think there may be any possible way to get to it in java?
Unread 02-04-2010, 07:21 AM
If you are writing your dashboard in Java, you have a couple choices.
The images from the cRIO are just a jpeg. There is a small header in front when it comes in the TCP port, but that is easily skipped and is there for identifying future image formats that may be used. So, you can use whatever Java libs you like to display the jpg. Then in the same drawing canvas, use line, circle, or possibly even pixel operations to draw your reticule. I'm not familiar enough with Java libs to help you with the exact drawing commands.
Presumably you are not using Imaq Vision on the dashboard PC, but if you happen to be, the C version of the Imaq libraries also contain the routines to overlay graphics on an image and display the result. I suspect it isn't worth the effort to call those from Java.
Finally, the code is there in LV if you would like to look at it and consider making your dashboard in LV.
Greg McKaskle
Unread 02-04-2010, 08:06 AM
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
If you are thinking of mounting a reticle on the lens, I think you will find that it will out of focus.
Al
WB9UVJ
www.wildstang.org
________________________
Camera For Driving? frenchie4111 Programming 5 01-28-2010 09:26 AM
Java/Netbeans Camera Code for Classmate PC and Axis Camera joshholat Programming 1 01-23-2010 02:59 PM
Camera for turning DustinB_3 Programming 18 02-17-2007 09:00 PM
Connections For Camera Eupher Programming 3 02-02-2005 02:35 PM
Looking for a Digital Camera AJ Quick Chit-Chat 7 03-02-2003 08:16 PM
