Enable Teleop in Robot Main
Is there a way to Enable Telopmode on the screen for Robot Main? because Teleop just closes, and when i deploy Robot Main, it teleop says its waiting for activation.
Re: Enable Teleop in Robot Main
That's what the driver station does.
No, but there is a way to enable the robot from the Driver Station. In fact, you must use the Driver Station application to enable the robot. Click the green "Enable" button on the Operation tab.
wait, so does that mean i cant just deploy the code ive made to the robot, so i have to actually build it to the robot then use the driver station?
You can still temporarily deploy your code to the robot, but you must run the Driver Station from the same Developer account as you are running your code.
It's under Windows Start -> All Programs -> FRC Driver Station |
| Robot Main.vi | Sauce | NI LabVIEW | 6 | 06-03-2010 01:24 |
| No Robot Main | Robopanda6 | Java | 2 | 31-01-2010 18:57 |
| Basic Robot Main vi | chinckley | NI LabVIEW | 7 | 03-03-2009 15:54 |
| Using Robot Main | LiLFiL | Programming | 1 | 14-02-2009 18:51 |
| Coordinating Robot Main VI with Autonomous VI | jjauss | Programming | 2 | 07-02-2009 09:26 |
