Go to Post I guess this is where theory vs reality comes into play. - PhilBot [more]
Unread 04-02-2010, 12:56
TroyCDH's Avatar
TroyCDH TroyCDH is offline
FRC #2450 (Radierbots)
TroyCDH is on a distinguished road
Ball 3 inch under
What are teams doing to ensure the ball does not roll more than 3 inches under the frame perimeter?
Do we know how this will be checked at inspection before competition?
I assume flexible material (surgical tube) would not be a good choice...
THANKS
Unread 04-02-2010, 12:59
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Ball 3 inch under
We're making a recessed opening in the front of the frame. The recess has a solid bar across it to prevent the ball going in more than 3".
Surgical tubing won't do the job....
Unread 04-02-2010, 13:02
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
It won't.
If a ball goes more than 3" under your frame during a match, you will be penalized. It's up to you to figure out how to not let that happen.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 04-02-2010, 13:14
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
This item is in discussion informally at the moment. When something has been decided, it will either appear on the Inspection Checklist or a Team Update if the decision requires it. Although this is mainly the refs call, inspectors and refs work closely to insure the rules are followed.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 04-02-2010, 13:20
Chris is me's Avatar
AKA: Pinecone
For 2791: on 3 robot sides, a hard frame member will prevent this. On one side, our kicker will.
One of the reasons an 8 wheel drive was chosen over, say, 4 wheels was so that there would be no gap to worry about balls getting in from. (At least, I think that's why!)
Unread 04-02-2010, 15:28
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
I believe, on our final machine, our roller will keep the ball from going in more than 2.75". After this we plan on having a hard stop 3" into the frame perimeter to eliminate any possibility of a ball ever going in too far.
Theoretically, if you're looking for something cheap, easy, and light-ish, you could use a piece of plywood as a hard stop. This would eliminate any questions about intrusion.
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Unread 04-02-2010, 15:31
Fennig247's Avatar
Fennig247 Fennig247 is offline
AKA: Fennig
FRC #0247 (Da' Bears)
Team Role: Scout
Fennig247 is a glorious beacon of lightFennig247 is a glorious beacon of lightFennig247 is a glorious beacon of lightFennig247 is a glorious beacon of lightFennig247 is a glorious beacon of lightFennig247 is a glorious beacon of light
Send a message via AIM to Fennig247 Send a message via Yahoo to Fennig247
I hope you all are designing the under part of your robot to not get caught on any balls that go under you say if a robot pushes one under you that is in a corner. Or the ones who are flying over the bumps that we all do not land on one. O and do not forget the favorite, if you wobble and a ball catches the wheel and spins it under you. Just wanted to throw that all out, was not meaning to sound rude, just wanted to let people know about the small issues I have seen in the past from aim high to even raise the bar.
Unread 04-02-2010, 17:23
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
It always pays to be able to demonstrate there is no possible way your robot could have broken rule X (whatever the rule happens to be that year). For example, since we aren't allowed to extend more than 90 inches vertical, design hard stops or mechanical limits to your height that can easily be proven to an inspector, judge, or ref. Since the ball can't go under more than 3 inches, design hard stops to prevent that, and be prepared to demonstrate.
That's not to say that exceptional circumstances won't happen (like bouncing over a bump and landing a ball)... but you want to make it as clear as possible that you aren't violating that rule during normal game play.
3-inch rule Pneumaticsman Rules/Strategy 1 16-01-2010 16:55
3 inch penetration longrange Rules/Strategy 4 13-01-2010 19:03
80 inch diameter? Pneumaticsman Technical Discussion 4 15-01-2008 08:54
Carrying the ball under the overpass but across the finish line BaldGuy Rules/Strategy 13 09-01-2008 14:53
Going over 6 inch step with 12 inch wheels Joe P Technical Discussion 25 12-04-2004 11:15
