Go to Post but look at the bright side, you will now be able to size 1/4-20 nuts with your forearm and i doubt there are many people who can say that :p - Greg Needel [more]
Unread 04-02-2010, 15:01
Team_2389's Avatar
Team_2389 Team_2389 is offline
FRC #2389 (Pirate Robotics)
Team Role: Webmaster
Team_2389 is an unknown quantity at this point
Saving Programming to the Robot
Is it possible to save the programming to the robot without having to redeploy it everytime?
If so then how?
Thanks in advance
TEAM 2389
Pirate Robotics
Unread 04-02-2010, 15:04
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
Re: Saving Programming to the Robot
What language are you using?
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
vhcook's Avatar
vhcook vhcook is online now
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Labview, C++, or Java, please.
Unread 04-02-2010, 15:06
Team_2389's Avatar
Labview
TEAM 2389
Pirate Robotics
Unread 04-02-2010, 15:08
ewoodring ewoodring is offline
AKA: Eric
FRC #2474 (Excel)
ewoodring is an unknown quantity at this point
Yes, It is possible, but you'll have to tell us what language you're using.
Unread 04-02-2010, 15:13
vhcook's Avatar
Reader of Things
AKA: Victoria
Ok, you'll want to go to the project explorer and at the bottom there should be an item called build specifications. Expand that, and you'll find one thing under it (can't remember what the text will read, as I don't have labview on this computer). Right click on that item and select "build" from the menu. There will be a bit of a wait for that to complete. When it does, right click it again and choose "run as startup". It will deploy your code to the robot and then ask you if you want to reboot the cRIO now. You do.
When it reboots it will have the code running and will use that code until you repeat this process with another build.
I hope this helps.
Unread 04-02-2010, 15:17
Team_2389's Avatar
Thumbs up Re: Saving Programming to the Robot
Thank you very much everyone! 5 gold stars for you all
TEAM 2389
Pirate Robotics
Saving an image to the Crio Tom Line NI LabVIEW 2 01-01-2010 11:31
Saving files on the cRio Bomberofdoom NI LabVIEW 8 16-02-2009 08:33
Programming the last thing a robot does... efoote868 Programming 13 29-01-2008 11:17
not saving one of the preferences Joe Ross CD Forum Support 3 12-05-2002 13:02
