taigene motor
are we allowed to use the taigene motor from delphi. not sure what rule it would fall under i cant remember when we get this one.
Re: taigene motor
If it didn't come in this year's kit, you can't use it. <R52> and <R53>.
Re: taigene motor
What about clause B in R52: (An unlimited number of COTS servos with a maximum output torque of 55 oz-in and maximum rotational speed of 100 rpm at 6 Vdc (e.g. HITEC model HS-322HD or HS-325HB servos, as provided in the KOP)
So long as the taigene conforms to these standards shouldn't it be allowed? Can anyone confirm the specs for it? |
Re: taigene motor
It's a motor, not a servo. Therefore, <R52-B> does not apply.
And I'd say it's a pretty safe bet (not remembering the specs offhand) that it can beat that output torque really easily, if not the RPM, even if it were counted as a servo. If you look at the specs for this year's window motors, the Taigene would be somewhat similar, IIRC. |
| Taigene Van door motor | scimino | Motors | 3 | 15-03-2008 15:34 |
| Taigene Window Motor Information | CoupeSprinter | Motors | 4 | 29-01-2008 20:27 |
| taigene motor shaft | wildabyss | Technical Discussion | 3 | 24-01-2008 17:11 |
| Taigene Motor Specs | Guy_E | Motors | 7 | 21-01-2008 03:25 |
| White Paper Discuss: Approx. Motor Spec for Taigene Motor | Joe Johnson | Motors | 2 | 22-01-2005 16:36 |
