Go to Post Build season can't come soon enough. - Ryan Dognaux [more]
Unread 04-02-2010, 17:22
I am error's Avatar
I am error I am error is offline
The Error
FRC #0686 (Bovine Intervention)
I am error is an unknown quantity at this point
Exclamation Driver station will not update
I have tried to install the update many times, but the dashboard is still in 2009 version. Any advise?
I am Error. Yes.
Unread 04-02-2010, 17:27
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Driver station will not update
Have you uninstalled it and then installed it? There is a bug in the installer.
Unread 04-02-2010, 17:30
I am error's Avatar
The Error
How would you uninstall? Is it called National Instrumants? Or is it somethiung else?
I am Error. Yes.
Unread 04-02-2010, 18:56
Rookie Year: 1997
The easiest (maybe the only way) is to run the installer again and tell it to uninstall.
driver station update starjedi300 Technical Discussion 2 04-02-2010 19:57
driver station firmware update tanguma26 Programming 1 14-02-2009 19:53
driver station firmware update bobbyt14 Programming 15 14-02-2009 15:05
Driver Station Update ExarKun666 FRC Control System 8 15-01-2009 10:39
Driver Station firmware update failure ofshea FRC Control System 8 13-01-2009 11:35
