running solenoids with C++ code
Can we run the solenoids only using a digital I/O port? This would have to run through a spike to work (I think). Or can we also use a relay I/O port directly? The manual is kinda fuzzy on this point.
What is the best approach? Which class works best? And do I need a spike to run a pneumatic solenoid? |
| cRIO Not Running Code?!? | JohnFogarty | Programming | 11 | 01-17-2010 07:08 PM |
| Running camera code wirelessly | windell747 | NI LabVIEW | 4 | 02-09-2009 09:27 PM |
| Issue with debugging/running code on cRio | 114Klaatu0x72 | Programming | 5 | 01-27-2009 02:02 PM |
| Problem running compiled code | jskene | Programming | 10 | 01-23-2005 09:13 PM |
| Controlling Solenoids With Victors | Brandon_Cmpvir | Electrical | 20 | 03-16-2004 10:21 AM |
