Go to Post If only more people could have the same attitude toward FIRST as they do toward their fellow teams! - Jaine Perotti [more]
Unread 04-02-2010, 17:53
StrykeForce StrykeForce is offline
FRC #2767
StrykeForce is an unknown quantity at this point
Vacuum Pump
Ok we have a vacuum pump and motor assembly. Its a off the shelf assembly. Is it leagle to run the stock motor? Or do we have to use a KOP motor, wich is way to much power. The assembly is a hargraves BTC-IIS series pump.
Here is the link to the Data sheet.
http://www.hargravesfluidics.com/pdf...Data_Sheet.pdf
Thanks
Hayden Taylor
Team #2767
Vacuum Pump Question nickcvet89 Pneumatics 3 21-01-2010 01:05
robot pump Vince lau Chit-Chat 2 07-02-2008 22:43
Pump RobDeCotiis Pneumatics 12 01-11-2002 21:31
Pneumatic Pump archiver 2001 3 24-06-2002 00:32
Pump Problems... archiver 2001 2 23-06-2002 23:58
