Go to Post I'd be more worried about getting struck by lightning right after winning the lottery. :p - evulish [more]
Unread 04-02-2010, 18:13
ASTECHZ2994 ASTECHZ2994 is offline
FRC #2994
ASTECHZ2994 is an unknown quantity at this point
Use of Globe Motor from 2009 KOP?
We are wondering if we would be allowed to use the globe motor from the 2009 KOP in this years robot. Our interpretation of the rules this year was no, however we would like other opinions...
Thank you,
All Saints ASTECHZ - 2994
Unread 04-02-2010, 18:17
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Use of Globe Motor from 2009 KOP?
You may not use the Globe motor from any previous years. Sorry. Other motors as outlined below may be used.
<R52> Motors specifically permitted on 2010 FRC ROBOTS include:
A. All motors, actuators, and servos listed in the 2010 KOP,
B. An unlimited number of COTS servos with a maximum output torque of 55 oz-in and maximum rotational speed of 100 rpm at 6 Vdc (e.g. HITEC model HS-322HD or HS-325HB servos, as provided in the KOP),
C. An unlimited number of FIRST Tech Challenge (FTC) servos (HITEC HS-475HB servos),
D. One, two, or three additional 2˝” CIM motors (part #FR801-001 and/or M4-R0062-12) in addition to those provided in the KOP. This means that up to five, and no more, 2˝” CIM motors can be used on the ROBOT.
With this added in...
<R24> Individual COMPONENTS or MECHANISMS retrieved from previous ROBOTS and used on 2010 ROBOTS must have their undepreciated cost included in the 2010 ROBOT cost accounting, and applied to the overall cost limits.
E. Identical one-to-one SPARE PARTS for motors, actuators, and servos provided in the 2010 KOP that may have failed or become damaged.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 04-02-2010, 18:32
FRC #2994
Smile Re: Use of Globe Motor from 2009 KOP?
Thanks a lot, we thought the same thing...we just wanted to be sure
Do you happen to know if there is a way to separate the globe motor from its gear box to swap in a different motor?
Unread 04-02-2010, 21:07
Travis Hoffman's Avatar Unsung FIRST Hero
Travis Hoffman Travis Hoffman is offline
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Travis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond repute
Use a small punch or nail to tap the roll pins along the gearbox/motor interface inward.
Travis Hoffman, Enginerd, FRC Team 48 Delphi E.L.I.T.E.
Encouraging Learning in Technology and Engineering - www.delphielite.com
NEOFRA - Northeast Ohio FIRST Robotics Alliance - www.neofra.com
NEOFRA / Delphi E.L.I.T.E. FLL Regional Partner
Unread 04-02-2010, 21:09
Bob Steele's Avatar
Bob Steele Bob Steele is offline
Professional Steamacrit Hunter
AKA: Bob Steele
FRC #1983 (Skunk Works Robotics)
Team Role: Coach
Bob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond repute
I have never heard of anyone ever using the globe transmission on a different motor.... not that it could not be done.... it would certainly be an interesting engineering project.
A faster solution would be to use a Banebot transmission for any of the mabuchi motors or the fisher price.
All of those motors can also be used with a variety of gear boxes from Andy Mark ...
Good luck!!
Raisbeck Aviation High School TEAM 1983 - Seattle, Washington
Las Vegas 07 WINNER w/ 1425/254...Seattle 08 WINNER w/ 2046/949.. Oregon 09 WINNER w/1318/2635..SEA 10 RCA ..Spokane 12 WINNER w/2122/4082 and RCA...Central Wa 13 WINNER w/1425/753..Seattle 13 WINNER w/948/492 & RCA ..Spokane 13 WINNER w/2471/4125.. Spokane 14 - DCA --Auburn 14 - WINNER w/1318/4960..District CMP 14 WINNER w/1318/2907, District CMA.. CMP 14 Newton Finalist w 971/341/3147 ... Auburn Mountainview 15 WINNER w/1318/3049 - Mt Vernon 15 WINNER w/1318/4654 - Philomath 15 WINNER w/955/847 -District CMP 15 WINNER w/955/2930 & District CMA -CMP Newton -Industrial Design Award
Unread 04-02-2010, 21:19
O-H
Good luck!!
While it may be sensible, I'm not so sure it would be faster...check availability of the Banebots P60's. We're pretty high up the waitlist, and ours won't ship until Monday (allegedly ). We've been waiting almost two weeks. If you're going to order, order them NOW.
A-M is also experiencing 1-2 day delays in shipping in-stock items, and their GEM500 planetaries are out of stock across the board. They do have the AM Planetary in stock.
Unread 05-02-2010, 00:11
MCahoon MCahoon is offline
FRC #3826 (Sequim Robotics Federation)
Rookie Year: 2007
MCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud of
As I recall from having one apart, the motor shaft of the Globe is significantly larger than that of the F-P or Mabuchi motors. It looked like it would be difficult to find a matching pinion which would press on any of the KOP motors.
If you do find a way, I hope you'll share it around - I like the size and robustness of the Globe gearbox and AM has those really nice little hubs just made for them.
Unread 05-02-2010, 10:48
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
Is the globe motor gearbox legal to use? From what I've heard no one has made or sold them in a long time.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 05-02-2010, 13:13
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Dad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud of
<R33> allows use of unmodified parts from previous KOP, however in this case they would be modified to be used with a different motor.
Best to ask on the Q&A if it is going on the final robot.
Unread 05-02-2010, 13:25
Unsung FIRST Hero
Rookie Year: 1996
Dad,
In past years, the Globe motor transmission was not considered to be part of the motor and therefore was allowed to be modified. It is likely, if one checks, that the transmission is still available from Globe and therefore would fit under the COTS definitions.
From 2009
<R53> So that the maximum power level of every ROBOT is the same, motors and servos used on
B. The gearboxes for the Fisher-Price and Globe motors are not considered “integral” and may be separated from the motors.
Al
WB9UVJ
www.wildstang.org
Unread 05-02-2010, 13:27
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
This is the important bit of information you need to decide, right?
Unread 05-02-2010, 13:53
Unsung FIRST Hero
Rookie Year: 1996
If not a COTS item the following rules (and possibly others) apply...
<R33> COTS items from ROBOTS entered in previous FIRST competitions or COTS items that are no longer commercially available may be used under the following conditions:
A. The item must be functionally equivalent to the original condition as delivered from the VENDOR (e.g. a part that has non-functional label markings added would be permitted, but a part that has device-specific mounting holes added would be prohibited), and
B. The item must satisfy ALL applicable 2010 FRC materials/parts use rules.
<R34> Parts custom-made for FIRST and provided to FRC teams in the Kit Of Parts for previous FRC competitions (e.g. 2006 FRC transmissions, custom-made motor couplers, custom sensor strips, FRC CMUcam II modules, etc.) may be used if the part is still functionally equivalent to the original condition and:
A. The part is now generally available as a COTS item from an accessible source, or
B. All information required to fabricate the part (e.g. complete drawings, materials list, Gerber Files where appropriate, etc.) is openly available, such that any team could fabricate the part (or have it fabricated for them).
Otherwise, such parts are prohibited from use in the 2010 competition.
Al
WB9UVJ
www.wildstang.org
Globe Motor team877 Motors 3 10-01-2009 12:52
globe motor lil_longo Motors 1 18-02-2006 12:27
globe motor chrisinmd Motors 9 11-02-2006 10:58
Globe Motor Team168 Programming 3 16-02-2003 11:50
globe motor use? archiver 2000 2 23-06-2002 23:39
