Go to Post FIRST is an organization that teaches students that smart is cool. - Warren Boudreau [more]
Unread 04-02-2010, 20:18
nyindojin nyindojin is offline
FRC #3059
nyindojin is an unknown quantity at this point
help with tower
hi, i was wondering does anyone know where the bottom pipe of the tower goes, let me elaborate further, in the drawings for the tower (cheap version), you have to screw in three pipes to the top of the tower, two of them line with the no-threaded pipes but third pipe is screwed at a lower distance, does anyone know what that distance is, how far from the top should it be? thank you...
Unread 04-02-2010, 23:52
ChrisH's Avatar Unsung FIRST Hero
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
ChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond reputeChrisH has a reputation beyond repute
Re: help with tower
Good question. Even the official drawings for the real field do not have this dimension. At least I couldn't find it.
They do have a dimension for a hole in a vertical pipe that is near the centerline of the lower horizontal pipe. The hole is 8.5" below the centerline of the top pipe. The centerline of the lower pipe seems to be between .25" and .5"above the hole. This would put the lower horizontal pipe 8-8.25" below the upper pipe.
For most purposes this should be close enough. You aren't supposed to hang on the horizontal bars on that side anyway. The interface with the ramp is the only reason to sweat it
Christopher H Husmann, PE
"Who is John Galt?"
Unread 05-02-2010, 11:00
My-smokepole My-smokepole is offline
FRC #0279
My-smokepole is an unknown quantity at this point
Re: help with tower
A clue look on the drawing for the real Field drawings. I don't have the info at my finger tips.
My-smokepole
David/toledo
Team 279
extend doring contact with allaince tower. omricohen General Forum 4 12-01-2010 08:50
Tower Dimensions Kpchem General Forum 10 10-01-2010 15:42
HELP!!! STUCK WITH SUB ROUTINES WITH THE IR!!! drewjones13 Programming 1 17-01-2008 20:52
Using USB with Serial Tower Mick Lego Mindstorm Discussion 11 07-11-2006 09:54
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
