Go to Post I see all these people complaining about the FIRST game having perverse penalties for playing defense...then we play without defense, and still people complain. - MrForbes [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 04-02-2010, 21:51
MGoelz's Avatar
MGoelz MGoelz is offline
Miranda: Design and Scouting
FRC #0234 (Cyber Blue)
MGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond repute
Send a message via AIM to MGoelz Send a message via Yahoo to MGoelz
Bending Tubes in Inventor
Our team was trying to figure out how to bend tubes or pipes in Inventor and couldn't find any adequate tutorials or anything, and we didn't see any older threads about it either. If someone could direct us to a good tutorial or can briefly explain how to go about bending a tube, it would be greatly appreciated.
Thanks
"The ideal engineer is a composite ... He is not a scientist, he is not a mathematician, he is not a sociologist or a writer; but he may use the knowledge and techniques of any or all of these disciplines in solving engineering problems."
— N. W. Dougherty
Unread 04-02-2010, 22:34
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Re: Bending Tubes in Inventor
Thanks
There are a whole bunch of tutorials on here, I'm not sure exactly what your thinking of, but to me it sounds like you can accomplish what you need by using the sweep feature.
http://mfgcommunity.autodesk.com/learning/tutorials/
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Unread 04-02-2010, 22:41
MGoelz's Avatar
Sure, we know we can use a sweep. We're really trying to learn to use the various features Autodesk offers better. We know that there is a way to do it, we're just searching for the how.
But thank you.
— N. W. Dougherty
Unread 05-02-2010, 10:23
ISGOI Howie ISGOI Howie is offline
FRC #2996
ISGOI Howie is an unknown quantity at this point
are you trying to use the tube and pipe feature? if so i also cannot get it to work. my problem is that our school firewall blocks out the autodesk content center but even when i try at home it cannot complete the feature.... my best guess is that you should try and make your own setting for what you ant then uuse it and see if it works
Unread 08-02-2010, 15:09
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
Team Role: Mechanical
joek is an unknown quantity at this point
tube and pipe is for like PVC and copper piping like you'd use for plumbing and gas
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 08-02-2010, 19:38
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
I would use the Frame Generator if you are trying to create frame members. Routed Systems for pnuematic, hydraulic lines.
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
AU 2007 Avatech Altogether Smarter Inventor Challenge 1st Place
http://home.pct.edu/~jmather/content..._tutorials.htm
Bending the Bumpers BeyondRamo General Forum 7 12-02-2008 18:39
Bending Aluminum Tubing? Kims Robot Technical Discussion 11 08-02-2008 03:53
Bending Metal Jeremiah Johnson FIRST Tech Challenge 2 01-05-2006 01:15
bending bumpers CharlieWilken Technical Discussion 3 19-01-2006 10:02
bending parts foobert FIRST Tech Challenge 4 15-01-2006 13:17
