Go to Post Don’t let the medals you win and the trophies on your mantel define who you are. Let it be the lives you’ve touched and the legacy you leave behind. - Sean Schuff [more]
Unread 04-02-2010, 23:21
DarKCroNo's Avatar
DarKCroNo DarKCroNo is offline
FRC #2670
DarKCroNo is an unknown quantity at this point
AXIS CAMERA HARDWARE SETUP
I'm not sure about this, however I'm wondering is the camera setup DIFFERENT from last year? We are using the same setup, which is using the SERVO motors. I'm wondering are we suppose to use that again? because in the program it talks about using a gyro and no values concerning the PWM connectors where the servos went. So if it HAS changed, I'm wondering how its set up? Do we juts mount the camera and place a gyro on the robot itself?
Java/Netbeans Camera Code for Classmate PC and Axis Camera joshholat Programming 1 23-01-2010 14:59
Help: "Setup Axis Camera" sloteera Programming 9 16-01-2010 00:59
Camera Setup ExarKun666 Control System 10 25-02-2009 19:18
Can't figure out the Axis camera setup... 2829ron Technical Discussion 6 20-01-2009 13:12
Setup Axis Camera - ERROR Bruno Inácio Technical Discussion 2 16-01-2009 12:37
