Go to Post Welcome to adulthood. Remember, patience is your friend. Denial is your shield. Bitter disinterest your salve. Your endless hours of crushing workload will be your strength. Good luck, soldier. - Koko Ed [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 05-02-2010, 11:00
adamdb adamdb is offline
adamdb has a spectacular aura aboutadamdb has a spectacular aura aboutadamdb has a spectacular aura about
AXIS M1011 camera - Is anyone using it?
After carefully comparing specs with the AXIS 206, we purchased this one as a replacement (our 206 disappeared sometime in the past year).
Is anyone successfully using this camera. We are having a runtime issue (see this post: http://www.chiefdelphi.com/forums/sh...threadid=81908) and I wanted to see if anyone else is seeing it. If you are successfully using the M1011, did you have to change any of the configuration beyond just setting up the FRC account and changing the admin password?
Adam Bryant
Programming Mentor
Team 1583
Ridge View Academy Rambotics
Axis Camera replacement silv940 Control System 9 31-01-2010 22:41
Java/Netbeans Camera Code for Classmate PC and Axis Camera joshholat Programming 1 23-01-2010 14:59
Is anyone using the Camera? GillSt.Bernards General Forum 19 05-03-2009 21:52
Axis Camera ehochstein Programming 2 21-02-2009 00:16
AXIS Camera nickmagus Programming 1 03-01-2009 20:06
