Go to Post Smokey the Fisher Price motor says only YOU can prevent rule infractions. - artdutra04 [more]
Unread 05-02-2010, 11:25
WarrenPW WarrenPW is offline
FRC #2085
WarrenPW is an unknown quantity at this point
cRIO Startup code corrupts on boot, reformatting doesn't help.
Hello,
This week we have been having trouble with the cRIO in two different ways. First of all, the cRIO somehow managed to set itself to get an address via DHCP, and though multiple reformats didn't help, we were able to fix this with the MAX Measurement and Automation Explorer, but now when we try to boot the cRIO with deployed code, the robot reboots a couple of times, and then the status light blinks four times every second. MAX says that the error is that the cRIO had rebooted to many times and had been put into safe mode because of a corrupt startup program, but the code looks fine in Labview, and when we load the default code from a new project, the same thing happens. Is it possible that more than the TCP/IP settings got changed in the cRIO?
Team 2085 Robodogs
cRio doesn't re-image Lilszamora FRC Control System 3 15-02-2009 21:06
changing code after it's set to run at startup smcmahon NI LabVIEW 4 11-02-2009 19:36
cRio losing connection when "run as startup" mgurgol Programming 2 12-01-2009 12:18
confused, some startup help... NetSkay Programming 1 31-10-2008 21:44
Reformatting Raven_Writer IT / Communications 27 16-07-2004 19:10
