Go to Post we are all in the same boat. We'll adapt and deal with the challange. No need nashing teeth over the little stuff... - wilsonmw04 [more]
Unread 05-02-2010, 12:34
GEARmaster08's Avatar
GEARmaster08 GEARmaster08 is offline
FRC #0876
GEARmaster08 is an unknown quantity at this point
What Joysticks are you using?
Hey everyone, I am am wondering what Joystick/s everyone is using to control there robot and if there is any reason you picked one joystick over the other?
THANKS FOR THE INPUT!!
Unread 05-02-2010, 17:24
markulrich's Avatar
markulrich markulrich is offline
Head Captain and LabVIEW Programmer
FRC #2129 (Ultraviolet)
markulrich has a spectacular aura aboutmarkulrich has a spectacular aura about
Re: What Joysticks are you using?
We're currently using the joysticks that came with the kit, which have worked without a hitch and work great for tank drive (the y-axis of each joystick controls one side of the robot), and the logitech gamepad controller (uses same protocol as the kit joysticks, so easy to program), which is similar to an Xbox controller and the secondary driver can use to control whatever is ontop of the robot.
My team is looking for an easy way to specifiy which version of the autonomous code we want to use using a USB device with lots of switches or pots (that information could be stored on the robot during autonomous-disabled before the match starts). Does anyone have any suggestions? (I know that we could mount switches on the robot or use the First Touch I/O module, but I'm hoping for a simpler solution).
Edit: my team's decided to get information from the new "Virtual I/O" function on the driver station during autonomous disabled before the match starts, so that our robot knows which zone it is in.
What are you using to Latch A Kicking Device Larrys_Panther Technical Discussion 7 02-02-2010 01:39
How many Joysticks are you using? MiniNerd24 Control System 31 25-02-2008 07:20
What drivetrain style are you using? Mike Nawrot General Forum 32 27-01-2008 16:32
What tool are you using to make weight? EricH General Forum 40 27-02-2006 19:46
What Motors/Drivetrains are YOU using? IA-Howitzer Motors 16 27-02-2005 15:01
