Go to Post I dont compete to win prizes, I compete to win Pride. - CircularLogic [more]
Unread 05-02-2010, 14:31
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Need a 1/2 to 1HP 120VAC 1ph 5/8" shaft motor for a dead lathe (SE MI)
Crud... We have a VERY old lathe here, whose AC motor has just failed. I need to get the lathe running again so we can get back to making parts.
Is there is anyone in the SE MI area with a decent surplus 1/2 to 1HP 120VAC 1-phase motor (5/8" shaft) underfoot that they don't need anymore (or a cheap source for a new one)? If so, please contact me via CDF Email ASAP at:
http://www.chiefdelphi.com/forums/se...ilmember&u=359
Physical frame size is irrelevant as it mounts on an external plate and I can make anything work. I just need to make sure it has a 5/8" keyway shaft so I can keep the same pulley set.
BTW... If you are anywhere near me (Ann Arbor MI), I'll be happy to drop everything and run out to pick it up.
adTHANKSvance !!!
- Keith
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
8 mm motor shaft to .5 drive shaft adaptor sbrumund Kit & Additional Hardware 11 10-02-2009 14:25
Banebots 1/2" shaft encoder for Toughbox? MrForbes Electrical 11 24-01-2008 21:40
Shaft size of Big "FP" CIM Motor Mr.G Motors 3 18-01-2006 18:32
supplier for 5/8" shaft david.clark Kit & Additional Hardware 2 17-01-2004 18:13
