Go to Post we are all in the same boat. We'll adapt and deal with the challange. No need nashing teeth over the little stuff... - wilsonmw04 [more]
Unread 05-02-2010, 15:53
robotic321's Avatar
robotic321 robotic321 is offline
FRC #1793
robotic321 is an unknown quantity at this point
Question Using holonomic Drive with Dual Joystick Controller
How would i do it? I got it to work fine with a side winder controller, but our driver wants to be able to move with the left joystick (front,back,left,right) and turn with the right joystick x-axis.
Unread 05-02-2010, 16:01
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Using holonomic Drive with Dual Joystick Controller
If it's working fine with an existing controller, then your code is probably good. All you should need to do is change which axis (and joystick) you feed into the rest of the code.
Unread 05-02-2010, 23:45
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
One of our student drivers asked us to do this as well. His reasoning was that the game Halo works that way, so they're already used to using it.
It was actually very easy to add. Just open the second joystick, break out the axis you need and feed the holonomic drive.vi at the rotate input with the axis value.
We had been using one joystick and using the trigger to switch to a rotate mode, but this is simpler and is more intuitive for the gamers on our team.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Holonomic drive vi with mecanum wheels dwodrich NI LabVIEW 7 18-01-2010 16:01
Using a spike with a VEX controller? AdamHeard VEX 2 20-11-2007 10:26
Using auxiliary joystick buttons with IFI controller. Eric W. Jones Programming 9 03-12-2006 22:26
Using Accelerometer with '04 controller sanddrag Control System 4 20-02-2004 12:18
White Paper Discuss: Dual-motor, dual-speed drive transmission design CD47-Bot Extra Discussion 9 03-09-2003 10:40
