Go to Post Patents are an issue of law which, alas, has little to do with engineering or common sense. - Mike Betts [more]
Unread 06-02-2010, 10:45
whatabouteve whatabouteve is offline
AKA: Dean Keithly
FRC #0245 (Adambots)
Team Role: Leadership
Rookie Year: 2007
whatabouteve is an unknown quantity at this point
"code doesn't load" solution C++
This link has a video tutorial for how to download code to the robot and convert the arcade drive to tank drive.
http://users.wpi.edu/~bamiller/Using...iveSample.html
We actually were freaking out because we thought a library was jacked up.
After much thought I came to the solution that Windriver was repetitively loading the first code we set the preferences for.
This process of setting the preferences can be seen in the tutorial above better than in the FRC Programming Guide.
NOTE: this is for if you are having problems where the old code is still running but the new code is not
ie. the code said tankdrive clearly but the robot was running arcade.
Unread 06-02-2010, 17:10
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Re: "code doesn't load" solution C++
Originally Posted by whatabouteve View Post
NOTE: this is for if you are having problems where the old code is still running but the new code is not ie. the code said tankdrive clearly but the robot was running arcade.
It's hard to estimate how much wasted time is avoided by just one of these videos -- suffice it to say 'a whole bunch'.
But I would dispute your note.
This video, and any others like it, are for any teams using the Wind River tools.
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
Unread 09-02-2010, 17:04
AKA: Dean Keithly
Rookie Year: 2007
on the contrary, it discusses a problem that is seen in many of the programming forums and while many of these videos are of suspect, this one really helped us get over the first difficult bump.
I actually skipped over the video 3 times looking for a forum that could help. After seeing it a 4th time and having no luck thus far, i finally looked at it. Today we are finishing the camera tracking code, the shooter code, and the arm code.
Basically this shows you the programming guide again. Although it is not a great substitute, together they can get code on a robot
Labview: Feedback node doesn't reset on "stop" kamocat NI LabVIEW 10 09-06-2016 23:43
Modified default code gives "code violation" scottmso Programming 8 10-02-2006 23:17
Code error on RC after downloading "bells and whistles" version of Kevins camera code DanDon Programming 6 10-01-2006 18:07
"Load Bearing Surface" Natchez Rules/Strategy 118 04-04-2005 04:36
