LabVIEW closing VIs on target upon deployment
Using LabVIEW with all of the latest updates, we get a list (see attached screenshot) telling us that a bunch of VIs are going to be closed on the target if we choose to continue with the deployment.
The error message is specifically this: Code:
This VI is part of a Real-Time Startup Application. All VIs on the target will be closed if you choose to apply and continue with deployment. |
Re: LabVIEW closing VIs on target upon deployment
This is normal and expected. It's telling you that code is already running on the cRIO, and making sure it is OK with you to stop the existing code and load your new code. Click OK and everything will be fine.
| Best Practice for Posting LabView VIs? | DonRotolo | National Instruments LabVIEW and Data Acquisition | 8 | 09-04-2010 22:37 |
| Merging/Comparing LabVIEW VIs | Terry Sherman | NI LabVIEW | 7 | 30-08-2009 10:30 |
| FOLLOWING the target using labview | psychomonkey | NI LabVIEW | 8 | 12-02-2009 07:42 |
| Multiple Targets in "LabVIEW Sample two-color target tracking code" | markulrich | NI LabVIEW | 7 | 29-01-2009 11:52 |
| LabVIEW - CMUcam finds target but cant track | bear24rw | Programming | 6 | 13-01-2006 21:43 |
