Go to Post TL;DR: The robot battery (and your car battery) aren't going to electrocute you unless you stab a positive and negative wire from them into your heart. In which case you have plenty of other problems besides. - Kevin Sevcik [more]
Unread 06-02-2010, 13:54
scorpions980 scorpions980 is offline
FRC #3017
scorpions980 is an unknown quantity at this point
problematic impact
today we finally completed the base of the robot and we were testing to see if it goes over the bump nicely. it worked fine but when we went full speed it seems the impact of the hit automatically disables the robot. and i mean disable by the setting on the notebook automatically goes to disable and we have to set it to enable again. does anyone else have this problem? and does anyone know a way to fix it if its not a issue about the impact? thanks
Unread 06-02-2010, 15:23
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: problematic impact
Does the Driver Station Communications status light go red when it disables your robot?
A possible cause might be an brief interruption in power that affects either the cRIO or wireless bridge.
Unread 06-02-2010, 15:53
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
I'm betting that the buttons on their gaming bridge are actuating in the slam down. One team has already seen that issue. Putting a piece of sticky tape over the buttons can help stop them from moving around, or you can change the orientation of the unit.
Impact of Bumps BrianCloutier Rules/Strategy 4 15-01-2010 13:05
G14 Match Impact SamC General Forum 15 22-06-2009 19:56
FAHA: Dealing with a problematic team member Beth Sweet General Forum 3 26-10-2007 10:22
Problematic 2004 RC behavior Danny Diaz Control System 1 21-01-2006 17:48
Impact of FIRST rbayer General Forum 1 05-04-2003 15:23
