Go to Post 5:20 - Lots of discussion about how FIRST pretty much wipes out the world of at least one object every year. - Andy Grady [more]
Unread 06-02-2010, 14:05
boya3706 boya3706 is offline
FRC #0020
boya3706 is an unknown quantity at this point
freshImage() routine anomaly
We need an asynchronous method of checking (from Java) to see that a new a new image is available from the camera. The documentation implies that the method freshImage() serves that purpose. However, it does NOT.
The documentation for the freshImage() method in the AxisCamera class says that its return value should be "true if the latest image from the camera has not been retrieved yet". The implication is that the return value will sometimes be false. However, our observation is that freshImage() always returns a value of true -- evidently because it actually waits for AxisCamera to have a new image.
Is there an asynchronous method (from Java) of checking that a new image is available from the camera?
Unread 07-02-2010, 03:53
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Rookie Year: 1997
jhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond repute
Re: freshImage() routine anomaly
I'm not sure if it used to block, but it doesn't in the current version. At least the C++ part of it doesn't. Is there something in the Java code that is waiting?
Have you updated to the latest (Feb 3rd or so) Java update?
Unread 07-02-2010, 10:29
FRC #0020
I haven't seen a java update for FRC posted on any site.... would you mind posting a link for it?
Unread 08-02-2010, 21:01
FRC #0020
JHersh, thanks for the reply. We finally figured it out. freshImage() is indeed working correctly.
At first, the problem was that our processing loop was running very long compared to the camera refresh rate. In that circumstance, of course, freshImage() would always return true.
Then, we commented out all the processing code -- including getImage(). We didn't realize that it was the call to getImage() had a side-effect that impacts freshImage(). Once we put the call to getImage() back into the code, a subsequent call to freshImage() indeed returned false.
Our apologies if we confused anyone. freshImage() has NO anomoalous behavior.
pic: 816's 2009 Robot! Anomaly V8.0 thefro526 Extra Discussion 3 15-02-2009 08:50
printf() inside interrupt routine? Nathan Programming 14 10-02-2008 16:44
Martin Gear Anomaly? sanddrag Technical Discussion 3 09-02-2005 15:34
Routine declaration syntax error (Or: Where's wlado?) Astronouth7303 Programming 15 24-03-2004 05:51
Master uP Initialization Routine Ulibrium Technical Discussion 5 24-01-2002 16:43
