closed-loop torque (current) wheel control for mecanum
Has anyone tried using closed-loop torque (current) control for a mecanum or holonomic bot, instead of closed-loop speed or voltage control?
Re: closed-loop torque (current) wheel control for mecanum
We used closed loop current control last year to prevent wheel slip, as we did not design in wheel counters and a "free wheel" with a wheel counter from the start. You had to use the Jaguars for this, the Victor pulse rate is too slow to get a reliable average current measurement.
Eugene |
The torque is proportional to the current, limit the torque to just below the torque that causes wheel slip, and your wheels never break traction. It was a good patch given the lack of wheel counters (including a free wheel) in that it only required current sensors and some software.
There are rubs: As the speed of the robot runs up, some of the torque (measured current) is tied up in drive train friction and because of this you lose a portion of the torque that you would like applied to the wheels. The best performance is obtained with just a little slip and you can best obtain this by using wheel counters (including a free wheel with a counter). Eugene |
| Radio Packet loss + closed loop control system = lunging robot | Dave K. | Control System | 5 | 20-02-2007 06:09 |
| Torque vs. Current in small CIM motors | robotguru1717 | Electrical | 2 | 08-01-2007 17:09 |
| PID control loops - closed loop feedback | KenWittlief | Technical Discussion | 56 | 26-04-2004 21:27 |
| How Can You Make A Closed Loop System???? | GRR_340 | Pneumatics | 6 | 21-03-2002 12:27 |
| Sensible Torque/Speed/Current Graphs | l1jmx | Rules/Strategy | 2 | 10-01-2002 09:47 |
