Go to Post Jeez, I love my job! :) - dlavery [more]
Unread 06-02-2010, 18:25
michael1991j michael1991j is offline
FRC #3139
michael1991j is an unknown quantity at this point
wiring and programing our optical encoders
hello
we are trying to set up our us first optical encoders. unfortunately there is nothing in the manual that I could find on how to do this task. now I have gone though the chief Delphi forum's and found a article that explained how to set up the encoders. from what it said is that I had to hook up our encoder by getting a two three pin cable and wire them like this
ground
power
signal a
then get another cable and put signal b on the other cable on the signal slot
and then plug them into our digital side cars
now if I have this set up right would anybody know happen to know how I would program this in c++. just to have it output the angle.
thank you
Unread 06-02-2010, 19:23
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Re: wiring and programing our optical encoders
WPILIB provides an encoder class (I believe) that can be used with the encoders.
It should count in "ticks". Not degrees. So you'll have to find out how many "ticks" are in one revolution of your encoder, and use that to convert to degrees.
In addition, the encoders are not "absolute" encoders. They do not have a zero-position that stays the same. Essentially, every time you fire up your code the zero will be in a different location. So if you are trying to use the encoders for absolute positioning, you either have to buy an absolute positioning encoder, make sure you set your mechanism in the same location every time and then zero it, or use a potentiometer suited to the application.
Unread 06-02-2010, 20:13
FRC #3139
does my wiring look correct i do not know
Unread 06-02-2010, 20:41
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Yes it does.
Kettering Motorsports
Unread 06-02-2010, 23:24
FRC #3139
hmm i wonder if it is somthing am doing wrong then
this is how i stated my code:
I state this inside my main class
Encoder encoder(1, 2, true);
and then in my teleop loop
I say
float tick = encoder.GetDistance() ;
printf("tick:%4.2f /n",tick );
and what i am getting is
tick:
tick:
tick:
.... and when I move my gear box i get no input
now i did noticed there is a spot for a jumper on the digital side car on the digital input sides do i need to put a jumper in there. the probem when i do that everything become nonresponsive until i remove it so does anybody know what am i doing wrong
Unread 06-02-2010, 23:51
Kingofl337's Avatar
Kingofl337 Kingofl337 is offline
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Rookie Year: 1998
Kingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond repute
Send a message via Yahoo to Kingofl337
try
initTeleOp(){
encoder.SetDistancePerPulse(.025); //this actually depends on your wheel size, gear ratio, encoder CPR
encoder.Start();
PeriodicTeleop(){
INT32 tick = encoder.GetDistance();
printf("tick:%4.2 /n",tick );
This should get you started
FIRST Team 501 PowerKnights - Mentor
FIRST Team 40 Checkmate - Mentor Alum
FIRST Team 146 Blue Lightning - Alumni
Unread 07-02-2010, 00:12
FRC #3139
thank you very much I will try it
Unread 07-02-2010, 00:58
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Originally Posted by michael1991j View Post
\now i did noticed there is a spot for a jumper on the digital side car on the digital input sides do i need to put a jumper in there. the probem when i do that everything become nonresponsive until i remove it so does anybody know what am i doing wrong
I don't know what "spot for a jumper" you're talking about. Can you describe it more fully? Your program says you have the encoder connected to DIO1 and DIO2. As long as the Digital Sidecar has good power, you shouldn't need to do anything else with the wiring.
Unread 07-02-2010, 02:35
FRC #3139
if you look at where circled in this picture you will see a + or - in that area
Unread 07-02-2010, 02:43
longrange longrange is offline
FRC #1070 (Royal Robotrons)
longrange is an unknown quantity at this point
Those are spare power connectors
Unread 07-02-2010, 12:13
FRC #3139
ok so that wouldnt power the digital io you needed jumpers for moters
Unread 07-02-2010, 15:01
Tom Line's Avatar
Rookie Year: 1999
The only time that you need to worry about a jumper on the digital side car (and someone can correct me here if I'm wrong), is when you are plugging in a servo.
What you did with the jumper was to jump power straight to ground - you short circuited the entire board. You are lucky it has built in protection or you would have fried it.
Please try to read through the various controls manuals provided by First if you haven't already. They provide a great starting point for someone new at this. Also, try to use punctuation and capitalization. It's hard enough to read through the hundreds of posts - don't make it any harder!
Unread 07-02-2010, 15:08
Software Architect
If you connected those two pins together, you shorted power and ground. That would certainly make everything else stop working.
Programing+encoders =? alaskabas Programming 2 24-02-2009 20:41
Wiring Gyros and Encoders? SuspectZero Electrical 3 03-02-2008 15:30
programing the vex optical shaft encoder youngWilliam14 Programming 10 11-11-2007 16:16
Optical Encoders misterikkit Robotics Education and Curriculum 7 22-12-2003 23:13
Programming Optical Encoders GrahamS314 Programming 5 09-03-2003 08:16
