Go to Post Sometimes i wish the robot could fit into my pocket. - GMAdan [more]
Unread 14-10-2010, 11:39
r2davis2's Avatar
r2davis2 r2davis2 is offline
no team (Purdue FIRST Program)
r2davis2 is an unknown quantity at this point
Re: pic: How 125 is rolling this year...
Those look very nice, I'd love to see how well they work out on an actual drivetrain.
Unread 14-10-2010, 13:42
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
Originally Posted by Bruceb View Post
Has anyone else tried this? Any success? Brando, what mods did you come up with for this wheel? Can I get a picture of the actual mold? I don't quite get how you get the entire wheel molded on all sides without any machining.
Thanks
Bruce
Here is a picture of just the mold
If you don't mind small imperfections on the face of the wheel then you don't need to worry about machining. Because you are using silicone as your actual mold cavity, the regular rules of molding can be stretched. Things like undercuts and 0 degree draft can be done because the silicone is compliant and moves out of the way of the way of the part when removing it from the mold.
These wheels are from our 2010 robot, so they were in this past years competition. Changes are in the works to make them even more reliable, cheaper, faster to turnover and easier to make.
-Brando
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 14-10-2010, 14:34
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
So, to make the mold you just laid the master on the bottom of the mold box and poured the silicone over it? The top side of the wheel is as smoothe as the urethane was poured, correct? Or did you pour it high and machine off the excess?
Bruce
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 14-10-2010, 16:03
Bruce
The mold "box" base was an aluminum plate with the bolt hole pattern drilled into it. This was then used to hold the master (aluminum) wheel down to the plate. I then hot glued a bucket with the bottom cut off around the wheel.
Yes, the top side is as smooth as the urethane is poured. Some of our wheels have just the poured urethane surface on top. As we tweaked the process though, we added more glass to the urethane, which resulted in a "bumpier" surface on the top. To enhance the look of the wheels we did start pouring high and machining the excess away. One of the enhancements to the process we are trying to make is to eliminate that step, although it only takes a minute or 2 for that operation per wheel.
-Brando
Unread 14-10-2010, 16:14
Bruceb's Avatar
What is your final chopped glass to resin ratio? Are you still using 1/2 inch pieces of glass or have you gone shorter?
Bruce
Unread 15-10-2010, 08:46
Bruce
Our pieces of glass are between 3/8" and 1/2". Right now to measure the amount of fiber we place in the mold, we place the chopped fibers in a cup and gently tap the cup on a table to flatten the fibers out a little bit. We use the same style cup to measure out the urethane needed for the wheel. We then use a 1:1 ratio of urethane to "tapped down" fiber by volume. Our wheels typically needed about 80 mL to fill the wheel safely, so obviously for the 80 mL of urethane, we needed around 80 mL of tapped down chopped fiber.
The amount of fiber we use is something we still want to play around with. I feel with the geometry tweaks we plan on making that we can reduce the amount of fiber necessary.
-Brando
Unread 15-10-2010, 10:55
Bruceb's Avatar
Have you looked into buying precut fiberglass? You can get in in pretty short lengths that might mold better.
Bruce
Unread 15-10-2010, 13:49
Bruce
We used chopped fiber at the time because we had cloth laying around that we could use right away. Certainly playing with the size of the fiber would be another variable to explore, and is something we'll certainly be looking into.
-Brando
How are all the rookie teams doing this year? WakeZero General Forum 20 21-02-2009 12:02
How difficult do you feel this competition is, this year? astephen68 General Forum 46 14-01-2008 16:02
How many teams were disqualified this year? FIXIT General Forum 0 25-04-2007 08:05
How Many Motors Have You Dropped This Year? littleelectron Motors 5 05-02-2004 16:03
