Go to Post As Murphy as my witness, things happen and will continue to happen. - Pavan Dave [more]
Unread 06-02-2010, 19:37
The Ars-sassin The Ars-sassin is offline
AKA: The Ars-sassin
FRC #2443 (N/A)
Rookie Year: 2007
The Ars-sassin is an unknown quantity at this point
Number of hubs allowed?
Does anyone know how many USB hubs you're allowed to use?
And for that matter, if it's allowed for one hub to have 4 ports?
Unread 06-02-2010, 20:33
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Number of hubs allowed?
Is there a rule against it? Did you look for a rule against it? If the answer is "No" and "Yes", then you're OK.
I would assume the answer would be that you can have another hub because the maximum number of devices is 6 (4 joysticks, Stop button, Cypress board) and the existing hub only has 4 ports, max of 5 items (the classmate has 2 usb ports), plus it would be possible for the Dashboard to require USB (probably to connect to another computer.
Kettering Motorsports
Hubs m3ch4num470r Technical Discussion 6 12-03-2008 21:15
Number of air accumulators allowed itsme Rules/Strategy 1 13-02-2008 15:14
What is the maximum Number of motors allowed? borabora Motors 6 10-01-2008 16:54
Number of members allowed in a team Bomberofdoom General Forum 24 21-08-2007 15:30
Pit Max Number Allowed seg9585 Rules/Strategy 7 16-02-2006 11:29
