Go to Post if you need a hammer you use a hammer and not an oscilloscope. - Andrew Schreiber [more]
Unread 02-06-2010, 09:07 PM
bsudduth bsudduth is offline
None #2751
bsudduth is an unknown quantity at this point
AxisCameraException
Like many teams, we too are having trouble getting an image from the camera on the dashboard.
We have updated the driver station (we have the needle gage on the bottom right),
The cRIO has been imaged with v19.
We have updated LabView and have successfully run the Setup Axis Camera utility.
We can instantiate the camera and set the resolution and brightness.
However, whenever we try to execute the getImage() method on the instance of the AxisCamera object, we get the exception shown below.
2 Questions.
1. Is the video feed supposed to display in the dashboard once the getInstance is called?
2. Has anyone else seen/overcome the following exception?
[cRIO] edu.wpi.first.wpilibj.camera.AxisCameraException: No image available
[cRIO] at java.lang.Throwable.<init>(Throwable.java:88)
[cRIO] at java.lang.Throwable.<init>(Throwable.java:102)
[cRIO] at java.lang.Exception.<init>(Exception.java:53)
[cRIO] at edu.wpi.first.wpilibj.camera.AxisCameraException.< init>(AxisCameraException.java:20)
[cRIO] at edu.wpi.first.wpilibj.camera.AxisCamera.getImage(A xisCamera.java:257)
[cRIO] at edu.wpi.first.wpilibj.templates.Lucy.HandleImage(L ucy.java:140)
[cRIO] at edu.wpi.first.wpilibj.templates.Lucy.teleopPeriodi c(Lucy.java:93)
[cRIO] at edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:179)
[cRIO] at edu.wpi.first.wpilibj.RobotBase.startApp(RobotBase .java:132)
[cRIO] at javax.microedition.midlet.MIDletTunnelImpl.callSta rtApp(MIDletTunnelImpl.java:60)
[cRIO] at com.sun.squawk.imp.MIDletMainWrapper.main(MIDletMa inWrapper.java:110)
[cRIO] at com.sun.squawk.Klass.main(Klass.java:2997)
[cRIO] at com.sun.squawk.Isolate.run(Isolate.java:1554)
[cRIO] at java.lang.Thread.run(Thread.java:231)
[cRIO] at com.sun.squawk.VMThread.callRun(VMThread.java:1499 )
[cRIO] at com.sun.squawk.VM.callRun(VM.java:305)
Thanks for your help.
Barry Sudduth
Team 2751
Unread 02-07-2010, 12:43 AM
Kingofl337's Avatar
Kingofl337 Kingofl337 is offline
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Rookie Year: 1998
Kingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond repute
Send a message via Yahoo to Kingofl337
Re: AxisCameraException
You should be getting an image back to your dashboard with just calling
AxisCamera.getInstance();
If thats not working then you have other issues? Are both LEDs lit on the cRio on network port 2? Did create the FRC login on the camera?
Also next time you call
AxisCamera.getInstance.GetImage(); do this
try(){
} catch (Exception e){
System.out.println("Get Image Failed" + e);
FIRST Team 501 PowerKnights - Mentor
FIRST Team 40 Checkmate - Mentor Alum
FIRST Team 146 Blue Lightning - Alumni
Unread 02-09-2010, 12:35 AM
None #2751
The final piece of the puzzle was creating the FRC/FRC account. We now get images. Unfortunately, we are experiencing a lag of 1.5-2.0 seconds. Progress comes in small steps....
Thanks,
Barry Sudduth
Team 2751
Unread 02-06-2014, 05:38 PM
solopilot solopilot is offline
Mentor
FRC #0293
solopilot is a name known to allsolopilot is a name known to allsolopilot is a name known to allsolopilot is a name known to allsolopilot is a name known to allsolopilot is a name known to all
Glad that was resolved. I had the same exception but perhaps with a more devious cause. The sample program was working fine, camera.getImage() was working; but my program was not. Pretty much the same code. I found that the imports were different. I had let NetBeans import files as necessary. Things started working when I copied the sequence of imports from the sample program. Weird.
